SRAM Derailleurs with Dura Ace Cassette
Postby SpinninWheels » Sat Nov 10, 2012 5:57 pm
Hi All,
Looking at a new bike (TT Bike) that is fitted with 2012 Sram Red.
I wanted to be able to use the wheels currently on my rodie (Zipp 404 FC clinchers) that have a DA 9700 cassette on them. I would like to have the situation where the wheels are fully interchangeable between the two bikes.
Anyone able to tell me if this is likely to be possible?
Cheers in advance,
SW
SpinninWheels
by BNA » Sat Nov 10, 2012 6:24 pm
Re: SRAM Derailleurs with Dura Ace Cassette
Postby toolonglegs » Sat Nov 10, 2012 6:24 pm
10 speed Dura Ace cassettes have exactly the same spacings as SRAM... You may need to recheck the derailleur levels, that's all.
For that matter 10 speed Campag cassettes also work perfectly with 10 speed shimano or SRAM.
Postby SpinninWheels » Mon Nov 12, 2012 11:03 am
toolonglegs wrote:10 speed Dura Ace cassettes have exactly the same spacings as SRAM... You may need to recheck the derailleur levels, that's all.
Thanks TLL, sounds like it will be an easy option!
SpinninWheels
Postby jacks1071 » Mon Nov 12, 2012 2:23 pm
SpinninWheels wrote:Hi All,
Cheers in advance,
SW
I've always found you need a small adjustment tweak if swapping between a Shimano & Sram cassette on the same bike. I'd sell the Sram cassette while its new and put a Shimano one on there as you'll end up with a better chance of swapping wheels without any adjustment.
jacks1071
Postby MichaelB » Tue Nov 13, 2012 8:18 am
Absolutely no probs.
Just did it on the test of the Azzurri Mezzo 90.
Swapped trhe XG-1090 cassette (11-23) for a DA-7800 (12-27), and 1.5 turns on the cable adjuster at the RD anmd all was sweet :D
MichaelB
Postby jules21 » Tue Nov 13, 2012 2:36 pm
jacks1071 wrote:I've always found you need a small adjustment tweak if swapping between a Shimano & Sram cassette on the same bike. I'd sell the Sram cassette while its new and put a Shimano one on there as you'll end up with a better chance of swapping wheels without any adjustment.
that may be the offset, i.e. where the cassettes sit relative to the freewheel, rather than any difference in spacing between cogs (which is the important factor).
jules21
