Sluggish shifting on small chainring
Postby lasertip » Sun Nov 11, 2012 4:42 pm
Hi guys,
I've just noticed that the rear derailleur shifting tends to be sluggish, but only when I'm on the small chainring.
Otherwise, it's nice, crisp shifting while on the large chainring.
I've tried adjusting tension using the barrel adjuster on the RD but it doesn't seem to help. Is it possibly a chain that's too long or do I just need new cables?
It's all in your head.
lasertip
by Forum Ads » Sun Nov 11, 2012 9:02 pm
Re: Sluggish shifting on small chainring
Postby jules21 » Sun Nov 11, 2012 9:02 pm
define 'sluggish'
jules21
Postby lasertip » Sun Nov 11, 2012 10:21 pm
jules21 wrote:define 'sluggish'
Like when I shift, I can feel the lever clicking into position but the chain doesn't shift.
Sometime the chain will decide to shift a couple of secs later.
Other times, I have to shift down another gear and the chain immediately shifts 2 gears down.
Not sure if you know what I mean..
If it helps, it's a 2010 Cannondale slice w/ SRAM red and SRAM TT shifters
lasertip
Postby Mulger bill » Sun Nov 11, 2012 10:44 pm
That sounds a bit like a gunged cable to me.
Postby lasertip » Mon Nov 12, 2012 12:21 am
I think the cables are pretty old. Ordered a jagwire racer kit to play with after uni exams :D
So do you think that it's just cabling, not chain length? Since shifting is only sluggish on the small chainring?
lasertip
Postby greyhoundtom » Mon Nov 12, 2012 4:19 am
If this problem has been there for a long time it could certainly be caused by a chain a fraction long. However if it is of recent origin it could be the derailleur spring losing tension or that area of the derailleur needing a good clean and lube.
Before getting involved in changing cables or shortening the chain give the whole derailleur a good blast with some WD 40.
greyhoundtom
Postby colaiacw » Tue Nov 13, 2012 6:40 am
It may also pay to check the length of the rear cable outer that runs from the frame to the derailleur stop. If it is too short, the cable can jam or catch slightly giving the impression of slow shifting.
Check the park tools website for detailed info http://www.parktool.com/blog/repair-help. Cheers.
Merida Scultura Evo 909 Full Dura Ace (Weekender) & Merida HFS 904 Com Full Ultegra (Trainer)
When you feel yourself struggling up a hill, just get over it!
colaiacw
Postby lasertip » Wed Nov 14, 2012 11:04 am
Cheers guys, will try and let you know how it goes :)
lasertip
cron
