Changed wheels and now a new clicking/Clunk sound
• Page 1 of 1
Changed wheels and now a new clicking/Clunk soundHey Guys,
Changed my stock wheels over to new Pro Lites. Now I am getting a noise when I stand up and put some power/pedal hard. No noise while coasting or anything. Was thinking BB but the noise was not there before. Something must have been affected when I changed the wheels over.... Any ideas? If more info needed just let me know what you need and I'll answer. Very strange. Joys of Cycling!!!
Re: Changed wheels and now a new clicking/Clunk soundPut the old wheels back on to eliminate them as a possible noise source. If the noise is still there then check the drivetrain for and loose bits.
Re: Changed wheels and now a new clicking/Clunk soundWheels are silent from what I can tell. Noise is when I decide to stand and accelerate up a hill or want to pick up speed. So doubt it's wheels, may check the drivetrain tonight and remove/put on wheels again and lubricate the chain.
I just thought this could would be a common thing, called the bike shop and said they would strip the bike down and reinstall everything for $180.... Kind of an extreme measure I think.
Re: Changed wheels and now a new clicking/Clunk soundDid you check the derailleur alignment after swapping wheels?
I ride, therefore I am.
Re: Changed wheels and now a new clicking/Clunk soundIf you have a speed sensor on your spokes check that it is not too close to the pickup. Sometimes the wheel flex can make it touch if it is too close.
As a matter of fact I did notice when I went for a ride yesterday the gear changing was a little off. What should I be looking for re: derailleur misalignment? Can you knock off the alignment after a wheel swap?
The cassette positioning on each freehub body of each rear wheel may be slightly different, this would need re-alignment of the derailleur ever so slightly if that's the cause of the issue. Twist the barrel adjuster on the derailleur to realign, remember to count the notch turns in case you make it worse, so you can reverse it. http://www.youtube.com/watch?v=SkzvfCaIbyQ
Makes sense. Will try and follow that YouTube clip. I guess worse case scenario it's off for a service anyways.
Re: Changed wheels and now a new clicking/Clunk soundDid you remember to fit the thin shimano washer onto the free hub?
Sounds silly. But... Apart from the noise what are your first impressions on the new wheels? John Beaven
2009 Giant CRX2 2010 Malvern Star Oppy C6
Re: Changed wheels and now a new clicking/Clunk soundAssuming this is indeed wheelset related: does that sound like brake rub? It could also be the spokes "setting" in. Are the wheels still in true?
___________________________ Giant Defy Advanced 0 Shogun Katana
Re: Changed wheels and now a new clicking/Clunk soundStupid dodgy workstand broke! So trying to adjust gears will be not fun. Might have to get a decent one as I want to save $$$ and start doing maintenance myself.
Might have to call Bike shop for a quick gear alignment. Wheels are true and silent. Noise is when I pedal with force and stand up on the bike... Also the gears are a little out of whack it seems from the wheel change.
Re: Changed wheels and now a new clicking/Clunk soundFWIW - I had to adjust - slightly - my RD stop screws and cable tension after putting on my new Comos with new cassette, as they were slightly out of adjustment compared to the old rim / cassette I had on the bike.
That may be the extent of your woes. cheers 'dale CAAD10 - Ultegra6700 | Giant Defy 1 - DA7800
Watch the video. If you feel confident, have a go. It's a heck of a lot easier than it looks, but if you screw it up and put the chain in to the wheel or the frame, it's an unhappy time... but this is usually done by over-confident people who think they know what they are doing. You will need to back off the limit screws a couple of turns first, get the indexing right, then reset the limit screws. It takes about two minutes if you have done it before. I ride, therefore I am.
Re: Changed wheels and now a new clicking/Clunk soundTry tightening the QR. This happened to me too...only clicked under load after a wheel change. tightened everything, tried a different BB...still that damn clicking. Laughed when i did up the QR and then all was good!
Re: Changed wheels and now a new clicking/Clunk soundJust an update re the noise. Took it to my LBS checked the bike over completely including gear alignment and supposedly it's my Bottom Bracket which needs a quick service. A common problem supposedly, mind boggling how this just happened now when I changed my wheel.
So getting that done on Monday as it was too late last night.
As soon as you step foot out of the LBS, get on the bike and give it a good cranking test.
Yeah will do. The LBS does lots of work on the bikes from my local cycling group so good person. Didn't charge me a cent to diagnose.
• Page 1 of 1
Who is onlineUsers browsing this forum: Bing [Bot] |
