Noobie mechanic type question
Postby sutty451 » Tue Nov 27, 2012 8:30 pm
Hi, have just bought a second hand set of Mavic Aksium (2011 model) for my roadie.
I want to fit a brand new ultegra cassette (10 spd) and have tried to do that tonight.....
I put the spacer onto the hub first then the individual cogs and spacers and finally the lock ring.
However, there is still a bit of lateral movement between the cogs which doesnt look or feel right (and certainly isnt evident on my current rear wheel).
Is there a wider spacer that you can put on first to 'pack' the cogs out a bit more....or i have i got something wrong somewhere.....
sutty451
by Forum Ads » Tue Nov 27, 2012 8:52 pm
Re: Noobie mechanic type question
Postby mitzikatzi » Tue Nov 27, 2012 8:52 pm
From Sheldon
..snip..and the included 1-mm spacer before installing a 10-speed cassettes on an 8- or 9- speed hub.)
Shimano CS-HG 1mm Sprocket Spacer
Did you instal a 1mm spacer?
mitzikatzi
Postby sutty451 » Tue Nov 27, 2012 9:16 pm
Yep, installed the 1mm spacer that came with the cassette.
sutty451
Postby Pottsy » Tue Nov 27, 2012 9:38 pm
Your missing the thicker mavic spacer
Pottsy
Postby sutty451 » Tue Nov 27, 2012 9:59 pm
Are they 2mm ones....? Will try LBS tomorrow. Assume i need that and the spacer that came with the cassette...? Giving me about 3mm?
sutty451
Postby TDC » Tue Nov 27, 2012 10:40 pm
yes correct. You need to use both spacers on these wheels
TDC
