Trek SLR will this headset fit
Postby Bentnose » Sun Dec 02, 2012 2:07 pm
I have a 2005 Trek SLR, Alpha Superlight Race Aluminium. It was bought as a frameset with the headset so I can't give you a model, the headset in it is an Aheadset intergrated I'd say a Cane Creek style would fit, would this one fit http://www.chainreactioncycles.com/Models.aspx?ModelID=6183
Bentnose
by Forum Ads » Sun Dec 02, 2012 4:23 pm
Re: Trek SLR will this headset fit
Postby TDC » Sun Dec 02, 2012 4:23 pm
This page might be helpful to you.
http://www.canecreek.com/headset-finder
TDC
Postby Bentnose » Sun Dec 02, 2012 6:34 pm
Hmm, it didn't have my bike in. The bearings sit in a small insert that sits in the frame but it and the bearings can be removed and put in with your fingers, might it be a semi intergrated headset? The top cover and bottom parts that are visible are very thin. I may have to post some photo's?
Bentnose
Postby Bentnose » Sun Dec 02, 2012 7:16 pm
This frame http://www.trekbikes.com/us/en/bikes/2005/archive/1500 is the same as mine, nice handlebars, not! What the hell is a slimstack?
Bentnose
Postby TDC » Sun Dec 02, 2012 8:51 pm
Ha ha...It's the flipped up stem that makes it looks freaky. Its hard to tell whether the headset is integrated or semi-integrated from Trek picture
edit: found this about the 2007. Frame looks the same
http://www.bikepedia.com/quickbike/Bike ... Lsy-O-k-So
TDC
Postby macca33 » Sun Dec 02, 2012 10:10 pm
I just picked up a 2008 Trek 1.9 with the aluminium frame and the headset was frozen, so I had to replace it - after cutting the old one off!
It is an integrated headset and I used one of these - http://www.cyclingdeal.com.au/buy/1-1-8 ... led/F-407K
It fitted and works perfectly.
I think the FSA one you linked to in your post would also work.
'dale CAAD10 - Ultegra6700 | Giant Defy 1 - DA7800
macca33
Postby Bentnose » Mon Dec 03, 2012 6:13 am
Thanks Macca33, that type should be the way to go, looks basically the same as the FSA one I mentioned also. Love the write up about the First Components.
Bentnose
