Vibrating front derailleur cable
Postby rangersac » Sun Dec 02, 2012 10:05 pm
So my front derailleur cable touches the downtube before it reaches the cable guide under the bottom bracket. It has the annoying habit of emitting an irritating rattle at high speed. I've tried playing with the cable tension but with no joy. Can anyone recommend a fix, or perhaps some kind of spacer than can be stuck to the frame to separate the cable, and not impinge on performance?
Thanks in advance.
If I can bicycle, I bicycle. ~ David Attenborough
rangersac
by Forum Ads » Sun Dec 02, 2012 10:25 pm
Re: Vibrating front derailleur cable
Postby winstonw » Sun Dec 02, 2012 10:25 pm
check that your cable guide was not screwed on backwards. i.e. front end is at back. it is unlikely the cable guide when fitted correctly, was intended to allow the cable to run as close to the down tube.
if you think it could help, consider a spacer placed between the cable guide and the frame. i.e. cut from firm rubber or plastic such as ice cream containers.
Fav Ride : Pottsville, Byron, Bangalow, Eureka, Dunoon, Nimbin, Uki, Mooball, Pottsville 200km 3000m
winstonw
Postby bychosis » Mon Dec 03, 2012 5:16 am
google cable donuts.
