Page 1 of 1
Shimano STI brifter maintenance
Posted: Mon Dec 03, 2012 3:15 pm
by WMC1
I was wondering what type of lubrication people would use on Shimano shift/brake leavers. I have Ultegra 6700 shifters and they feel a little heavy to operate. This bike I have them installed on is used occasionally in rainy weather and I have not touched them in 16 months of use.
I have heard of people using spray lubes (not WD40) to penetrate deep inside the leaver mech’s. If so any good brands out there to recommend and would this be effective?
Re: Shimano STI brifter maintenance
Posted: Mon Dec 03, 2012 3:47 pm
by familyguy
I've read people having good results with WD40 to clean (really fill them up and let them drain), and then using a lube after the WD40 dries up. Lanox, something like that.
Posted: Mon Dec 03, 2012 4:12 pm
by Nobody
I think the Bicycle Tutor used to recommend spray grease for shifter mechanisms, once cleaned and dry.
Posted: Mon Dec 03, 2012 4:32 pm
by WMC1
Thank you all for the replies. I will grab a can of lube and see how i go. Cheers.
Posted: Mon Dec 03, 2012 4:52 pm
by jacks1071
Weldtite (I think thats the right spelling), make a spray lube with teflon in it which is what I use. You don't need much in there though and don't go balistic with it as you don't want slippery levers or bars.
Posted: Mon Dec 03, 2012 5:42 pm
by sogood
Have you looked at your cables? These stiffening problems are more commonly caused by aging cables than by the brifter. Take a look.
Posted: Mon Dec 03, 2012 7:44 pm
by toolonglegs
Your supposed to service them?... probably 100K kms on my Ultegra 9 speeds ones and they have never been touched in over 10 years, my DuraAce ones are from 2006, same story.
Posted: Mon Dec 03, 2012 9:12 pm
by biker jk
toolonglegs wrote:Your supposed to service them?... probably 100K kms on my Ultegra 9 speeds ones and they have never been touched in over 10 years, my DuraAce ones are from 2006, same story.
Admittedly, in the new series (5700, 6700, 7900) the shifting mechanism is exposed and hence more susceptible to dirt, etc. Still, my Ultegra 6700 shifters have done 12,000km and are running as super smooth as day one, despite not spraying them with anything.
Posted: Mon Dec 03, 2012 10:28 pm
by warthog1
biker jk wrote:Admittedly, in the new series (5700, 6700, 7900) the shifting mechanism is exposed and hence more susceptible to dirt, etc. Still, my Ultegra 6700 shifters have done 12,000km and are running as super smooth as day one, despite not spraying them with anything.
One of my set of 6700 shifters has had the snot knocked out of them when I went over the bars at 50 odd kmh on a descent. Ground the suckers away a fair bit too :( . New set of rubber grips and all good :). Well still a bit scratched on the levers but they shift fine.
Posted: Mon Dec 03, 2012 10:40 pm
by Mulger bill
I'm with Sogood here, try the simple things first.
Posted: Tue Dec 04, 2012 7:19 am
by WMC1
Hi all, all great responses to my question. Thank you so much.
I have replaced the gear cables inners and outers with a Dura Ace set. Also cleaned and lubed the front and rear derailleurs and adjusted all the alignments and front derailleur operation. I gave the guts of shifters a squirt of spray lube and the they now feel like new.I must of had some gunk in there as what came out was not looking good. I will see how they perform over the next few days.
I agree with the comments that dirt and grime can easily get into the innards of the shifters and grit would certainly have an effect on the mech operation.
Cheers all. :D
Posted: Tue Dec 04, 2012 6:21 pm
by usernameforme
Off topic, but its related to the Title... I tried to rebuild a Shimano STI, I strongly recommend against it. The internals are more complicated than a swiss watch, if you're in a good mood and you don't want to be I suggest taking apart the shimano brifters, putting all the parts into a jar, giving it a good shake and trying to re-assemble it, I guarantee a dose of frustration :twisted: .
