by anthonyje » Sun Apr 27, 2008 9:26 pm
Hi all,
put some new xtr dual control levers on my mtb and set up the cables to the FD and RD. Even went so far as to use a torque wrench to adjust the pinch nut holding the cables to the recommended tightness! first time I ever bothered, but I figured new fancy stuff deserved the best. Anyway, after a few gear movements the last 6inches of the cable to the FD had acquired a rough barber pole feel - I think one of the filaments has pulled a bit. However I couldn't see an obvious problem at the cable chop end.
Any previous known issues with xtr cables?
Does it sound like the pinch nut pressure or a cable fault?
SHould I replace the cable or soldier on?
Thanks.
Ant
anthonyje
by Forum Ads » Sun Apr 27, 2008 9:50 pm
by Hawkeye » Sun Apr 27, 2008 9:50 pm
Did you put the alloy crimp cap on the end of the inner?
Hawkeye
by anthonyje » Sun Apr 27, 2008 10:34 pm
ahhh
the old alloy cap on the cable inner trick.
have to admit i didn't think it was functional to that degree, just a way to stop the fray. so i haven't put it on yet.
could it be a causative omission?
anthonyje
by Kalgrm » Sun Apr 27, 2008 11:08 pm
Check that the cable is held by the little groove in the clamp area of the FD. It sounds like not every strand was secured when you tightened the hex-bolt.
I used to use the crimps, but I'm happier with soldering the trimmed cable now.
Graeme
Kalgrm
by rustychisel » Wed Apr 30, 2008 3:05 pm
Coriolis force = Southern hemisphere
Yeah, sure. Err, why not. Cut with excellent cable cutters and use a thingamebob on the end.
rustychisel
by Kid_Carbine » Mon May 05, 2008 10:24 am
Kalgrm wrote:Check that the cable is held by the little groove in the clamp area of the FD. It sounds like not every strand was secured when you tightened the hex-bolt.
Cheers, Graeme
Stainless cable is hard to solder.
To find the cause of the problem, remove the cable from the bike cimpletely & examine the inner wire carefully, full length.
If it's perfect, then examine whatever lengths of outer that you have.
Repair or replace as necessary, lubricate, refit, adjust, enjoy.
Carbine & SJH cycles, & Quicksilver BMX Now that's AUSTRALIAN to the core.
Kid_Carbine
by munga » Mon May 05, 2008 11:59 am
i dont have a soldering iron, so before i cut the cable, i douse the cutting area with superglue, then crimp a pop rivet body (tap out the mandrel, or nail, then youre left with the body) onto the end of the cable inner.. works for me
by Jean » Mon May 05, 2008 12:11 pm
munga wrote:i dont have a soldering iron, so before i cut the cable, i douse the cutting area with superglue, then crimp a pop rivet body (tap out the mandrel, or nail, then youre left with the body) onto the end of the cable inner.. works for me
I admire your lateral thinking and resourcefulness, but cable ends are worth about .00000002c each (or somthing like that). A LBS will probably give you a handful and refuse to take your 80c because it's too much hassle to open the till - they usually do for me.
Jean
by munga » Mon May 05, 2008 12:15 pm
i've a lot of rivets
and some day you might need to replace a cable on a sunday and you might not have any cable ends..
