Hi,
Working on my next rebuild project a 1988 steel roadbike, fitted with Suntour Sprint 9000 drivetrain.
* Rear Hub Shimano 105 with Suntour Winner Pro 7Sp Cluster (removal with SUNTOUR 4-key removal tool No. TA-320).
* Chain Suntour SP6200 - Chain is neglected, presently soaking in Two stoke mower fuel to see if I can recover it.
=>> Not sure whether this post should be posted in "BNA Shed" or "BNA Retro"…SuperMOD, can move or link it if thought necessary…...
Some background on SUNTOUR SPRINT here
Suntour History a & Suntour History b
Chain
SUNTOUR PRO =>> SP-6200
•Dia-Hard pin treatment •High arch inner link plate* Finish: Silver (outer link)
Black (inner link) Size: V6"x%2" ultra narrow Pin width: 7.3mm Weight (116 links): 331g 'When fitting SP-6200 always ensure that the cut-away portion of the high arch inner link faces the centre of the chainwheel when viewed from the chainwheel side of the bicycle
SP6200 a, SP6200 b, SP6200 c
=>> notice the unique chain links......
Suntour Cables
Suntour Genuine Cables
Group Set
Sprint 9000 Groupo a, Sprint 9000 Groupo b, Sprint 9000 Groupo c
NOS Full Group Set
Sprint 9000 Groupo d
Very neat Biddle Time Trial with SUNTOUR Sprint:
Biddle Time Trial
Considering all this I have a few Qu's, hoping someone can help……(as until now I have only had Shimano 600AX & Shmano 105.)
1) Can you measure the wear of a Suntour SP-6200 chain with a Park Tools CC-2? What would be the expected reading on a new chain? What would be the wear limit? Does someone have a NOS SP-6200 Chain Technical leaflet? Can you still buy the joining pins?
2) If the SP-6200 Chain cannot be recovered, is there somewhere in Australia that would have NOS for sale? I can see that some NOS SP-6200's have sold on ebay in the recent past ex USA etc
3) Do you think it is worthwhile trying to get the SUNTOUR Sprint 9000 drivetrain functional? ie clean everything probably new cables, and outers, recovered chain (or new chain)….or is it likely that it will chatter under load and shift poorly ie never with the same precision as my replacement option of NOS late 1980's Shimano 600 drive train?
4) Can the Suntour Winner Pro Rear Cluster be removed and replaced with a late 1980's Shimano 600 Cluster using the existing Shimano 105 rear hub? (I have to borrow a 4 Prong Suntour Removal tool to take off the existing Winner Pro cluster, just wanting to know before I head down that path)
5) Can the Shimano SIS Down tube shifters be fitted onto the Suntour Accu-Shift "Click" indexed down tube shifters Bidon Mounts?
6) The rear cluster ratchet feels okay but my preference is to strip it down and instal new grease on the bearings and pall teeth mechanism, are the Suntour Winner Pro rear clusters suitable to disassemble?
7) The OEM Suntour install doc's talk about using the Special Suntour Cable outers, ie not standard run of the mill spiral sheath, rather the platted wire sheath. "Jagwire" after marker cable outers have a platted wire sheath can these be used successfully with new stainless steel cables…..instead of the "Suntour Specials" ?
=>> Thoughts and experiences with Suntour Sprint 9000 Drive train welcome.
Thanks,
Rob.
