Page 1 of 1
Wheels stuck - Raleigh Twenty
Posted: Fri Dec 14, 2012 8:50 pm
by TomBikes
I'm fixing a Raleigh Twenty and I'm pretty much done, i just need to replace the front tube. Problem is, the wheel wont budge from the frame. The nuts are off and there is nothing which seems to be holding it on, I can't see any rust either. Any ideas what i could do? I though of prying the forks a bit but there's nothing to leverage against except the spokes, which I don't think would be a very good idea. Any ideas?
Re: Wheels stuck - Raleigh Twenty
Posted: Fri Dec 14, 2012 9:06 pm
by thecaptn
You could try tapping the axle with a hammer while placing downward pressure on the wheel. just be sure to protect the thread on the end of the axle by screwing a nut onto it and hitting that instead of the exposed shaft. good luck
Assuming of course you've released the brake caliper
Posted: Fri Dec 14, 2012 9:31 pm
by TomBikes
The tire is fully deflated so their is no problem removing it without disengaging the brake caliper. It is thinner then the rim. I'll give that a shot tomorrow and hopefully I get some success. Thanks!
Posted: Sat Dec 15, 2012 8:36 am
by foo on patrol
Is there one of those washers that have the little hooks that locate into the the fork and stop the wheels from falling out?
Foo
Posted: Sat Dec 15, 2012 11:31 pm
by TomBikes
foo on patrol wrote:Is there one of those washers that have the little hooks that locate into the the fork and stop the wheels from falling out?
Foo
Yeah there is. Any tips?
Posted: Sun Dec 16, 2012 8:58 am
by thecaptn
SMACK IT WITH A HAMMER!!!
No don't, You should be able to gently lever it out with a screw driver.
Posted: Sun Dec 16, 2012 9:41 am
by paragonman
to get the wheels out of my twenty, I have to spring the drop outs apart and at the
same time use my index fingers to lift the wheel of the drop outs, the cone locknuts
have a sort of ridge which slots into a recess inside the drop outs.
hope that makes sense.
Posted: Sun Dec 16, 2012 11:26 am
by Mulger bill
According to Sheldon 20's ran to a non standard axle diameter and hub spacing, could this have sopmething to do with it?
If it has the tabbed washer, that'll have to come off to release the wheel.
Posted: Sun Dec 16, 2012 2:18 pm
by TomBikes
Thanks for the help, i just had to pull the forks a little and lift the wheel out. They are pretty solid forks!
