How do you setup a ute tray to carry two road bikes
Postby BoardRider » Sun Dec 23, 2012 12:42 pm
Hi just purchased a ute.
I was wondering if anyone has any advice as to the best way to set it up to carry to to road bikes safely.
Thank you in advance
Board Rider
"Motivation is what gets you started. Habit is what keeps you going."
Source Unknown
BoardRider
by BNA » Sun Dec 23, 2012 12:52 pm
Re: How do you setup a ute tray to carry two road bikes
Postby il padrone » Sun Dec 23, 2012 12:52 pm
A friend of mine set his ute up with standard roof bars over the tray, fastened to the channels, and roof bike-mounts fitted to these. The tray has a sliding 'rolladoor' style shutter. This means the bikes are readily accessible, but at the same time the tray functions as a useable, lockable load-space that can be accessed without removing the bikes.
You can sort of see the rig here
Postby BoardRider » Sun Dec 23, 2012 1:12 pm
That friends very inventive Pardone .
I was thinking of a bracket for the forks.There seems to be a few available not sure what actually works.
Was that a Pic from a cycling trip ? Park looks packed.
Board Rider
Source Unknown
BoardRider
Postby il padrone » Sun Dec 23, 2012 1:17 pm
Yep, a cycling club base-camp. We had about 56 people in tents and cabins over the Melb Cup Weekend.
Postby JBark » Sun Dec 23, 2012 1:25 pm
I know a popular choice back when I was in the US was the bolt down fork mounts like these:
http://www.amazon.com/Thule-821-Rider-B ... 000QV3NWU/
You can attach them right to the bed/tray, but most people I knew just attached them to a nice solid piece of wood so they were a bit more portable. Easy to find a way to secure the wood plank without permanent holes, too. There's a couple expandable mounts that work like that, but they're quite pricey. They get good reviews on Amazon,though.
http://www.amazon.com/Thule-822XT-Bed-R ... 0002MBPB4/
JBark
Postby BoardRider » Sun Dec 23, 2012 2:12 pm
Thanks JBark , the brackets look just right.
Board Rider
Source Unknown
BoardRider
Postby winstonw » Sun Dec 23, 2012 2:55 pm
Will take pics of my mates' home made front fork brackets. Just quick release levers inserted through appropriately cut aluminium.
One has it on the back of his trayback, and the other does the block of wood which goes in his VW Caddy Van.
Fav Ride : Pottsville, Byron, Bangalow, Eureka, Dunoon, Nimbin, Uki, Mooball, Pottsville 200km 3000m
winstonw
Postby antipodean » Sun Dec 23, 2012 3:36 pm
2010 Oppy Pro
2013 Boardman CX Pro
2007 Giant TCR C0
2012 KHS Yuma 29er
2008 Kona Dawg
antipodean
Postby Bentnose » Sun Dec 23, 2012 4:52 pm
I have a roll top with bike racks on top, I've also seen people use the Flexiglass lids the same way, though the roll top can be be fully opened with the bikes on and the Flexiglass lid not so much
Bentnose
Postby open roader » Sun Dec 23, 2012 8:47 pm
I set up my tray like this. I have two (one permantly fixed to the lid of the tool box and one added to the floor on the drivers side when required) of these Yakima lockable floor mount front axle brackets and a pair of threaded steel rings behind to tie down the rear wheels. This set up takes 2 minutes to load and unload the bike and has not passed a recent 4 hour part dirt road long haul trip last spring.
open roader
Postby DarrylH » Sun Dec 23, 2012 9:00 pm
In the back of my 4WD I use a block of 4x3 timber cut to the hub width and drilled to take an old front axle. Works just as well and is a lot cheaper - ie free.
DarrylH
Postby dale79 » Tue Dec 25, 2012 6:30 am
this is mine,,
can get 2 road bikes or 2 MTB on it with adaptors to go to 15mm or 20mm axles..
dale79
Postby Bobbybobson » Tue Dec 25, 2012 7:51 am
dale79 wrote:this is mine,,
So is that your road or the MTB?
Bobbybobson
Postby dale79 » Tue Dec 25, 2012 8:16 am
thats my new road bike santa gave it to me this morning!
dale79
Postby Bobbybobson » Tue Dec 25, 2012 8:36 am
The colour scheme is very hot but the bars don't match the saddle.
Bobbybobson
Postby visrealm » Wed Dec 26, 2012 6:06 pm
Plus I think you could reduce your rolling resistance by fitting narrower tyres.
2012 Avanti Cadent 1.0
2004? Giant Yukon MTB
visrealm
Postby il padrone » Wed Dec 26, 2012 6:40 pm
Not sure about the effectiveness of this rear fairing idea. UCI will ban it.
