by _mike_ » Sun Dec 23, 2012 11:41 pm
Anyone have any tips to stop the spokes rotating on the rear wheel / non drive side. Doesnt take long to straighten them with the nipple moving at the same time so tension isnt changing.
I thought maybe a dab of Contact Adhesive at either end of the spoke?
Thanks Mike
_mike_
by Forum Ads » Mon Dec 24, 2012 6:54 am
by bardygrub » Mon Dec 24, 2012 6:54 am
Hi Mike, Have a look through this post; viewtopic.php?f=34&t=55696 loctite, or take wheels back if they are still under warrenty. Hope this helps
bardygrub
by _mike_ » Tue Dec 25, 2012 11:12 am
Thanks for the reply. Have read that thread before. The spokes aren't unwinding from the nipples and wheel remains true. Entire spoke is rotating. Guess I'll just keep having to keep straightening them after each ride. When standing / pushing hard on pedals I can hear a faint metallic noise which is probably the spokes moving. I weigh 77kg for reference
_mike_
by toolonglegs » Tue Dec 25, 2012 6:20 pm
Drop of locktite into the holder around the base of the nipple... might hold it in place, while not affecting the nipple to spoke joint at all.
by _mike_ » Tue Dec 25, 2012 8:43 pm
thanks TLL. Will give that a try before the CA. The hobby grade CA i have might make a mess if if gets anywhere else
_mike_
by toolonglegs » Tue Dec 25, 2012 9:03 pm
Just clean the area really well before applying... a good spray of brake clean etc would work well... put a good drop in each holder then give the wheel a good spin up ... hopefully the centrifugal force will make the locktite settle well in that area, then leave it over night to dry.
by twizzle » Tue Dec 25, 2012 9:38 pm
Loctite anti-tamper / super-wick-in. My preferred bike loctite. Hi-strength, so be careful for small alloy parts (eg. Bont shoe captive T-nuts).
Sent from my iThingy...
I ride, therefore I am. ...real cyclists don't have squeaky chains...
twizzle
by _mike_ » Wed Dec 26, 2012 2:11 pm
Thanks guys. Areas were clean where I applied the Loctite (wheels 300k old). I removed the wheel last night and let gravity work , allowing a little time in each position. Good tip tll regarding centrifugal force. Do that next time if it needs reapplying. Head out for a short ride later on in the day in the 40deg heat Report back if it works
_mike_
by twizzle » Wed Dec 26, 2012 9:08 pm
Nipples are often lubed for assembly, so might look clean but won't allow the loctite to stick. Brake cleaner is the Q&D solution.
twizzle
by _mike_ » Wed Dec 26, 2012 11:34 pm
Good point. Would explain while a little of the loctite wasnt set
It worked anyway. 2 spokes moved rotated <1mm. Every ride at least 5-6 would rotate ~30-90 deg. Added a little CA so i dont think they should budge.
thanks Mike
_mike_
Users browsing this forum: barefoot, im_no_pro
