I recently upgraded (at massive cost) to a new Cannondale Bad Boy which is great.
Only issue is the chain keeps coming off, anyone experience this and what did you do about it?
Cannondale Bad Boy - Chain Problem
• Page 1 of 1
Cannondale Bad Boy - Chain ProblemI recently upgraded (at massive cost) to a new Cannondale Bad Boy which is great.
Does the chain come off the front ring?....if so on its own or when you change gears?...if it is one of these things it needs a front mech adjustment.
If it isn't these then spin the cranks backwards...if the chain runs smoothly backwards then fine...if it skips off the rear cluster or james up in needs a rear adjustment...
Thank you, it comes off the rear.
I'll take it back to the retailer tomorrow and hope I can get home and back to work ok in the meantime. Thanks again.
When it comes off the rear does it go off the back of the big ring or off the small ring...pretty simple adjustment to tide you over till the shop looks at it...if chain keeps going over the back it can damage the wheel and frame.
Had it fixed now, thanks heaps for the advice.
• Page 1 of 1
Who is onlineUsers browsing this forum: laterstarter |
