Boron fibre prepreg - free to a good home
Postby Mark Kelly » Thu Dec 27, 2012 12:50 pm
I have some boron fibre prepreg left over from an experimental frame project. I don't have enough freezer space to store it so I'm giving it away to anyone who wants to play with this amazing material (stronger, stiffer and tougher than carbon fibre, also six times the price). There's a little over a metre of 150mm unidirectional prepreg, cured thickness is 0.15 mm. The resin is 120 C cure so you'll need a temperature controlled oven.
If you've never worked with boron before: avoid cutting it, grinding it or sanding it if you can - the splinters are unbelievably sharp and PAINFUL. The best method I have found is to cut the prepreg to shape as accurately as possible so no post-cure shaping is required. A pizza cutter on a plastic board works well.
Mark Kelly
by BNA » Fri Dec 28, 2012 7:58 pm
Re: Boron fibre prepreg - free to a good home
Postby Mark Kelly » Fri Dec 28, 2012 7:58 pm
Boyracer
I've sent you two PMs but they are showing in my outbox not in sent messages, buggered if I know why.
Transport is no problem, it'll fit in a 3kg express post bag. I need your address.
Mark Kelly
Postby Mulger bill » Fri Dec 28, 2012 8:58 pm
Mark Kelly wrote:I've sent you two PMs but they are showing in my outbox not in sent messages, buggered if I know why.
Standard practice with forum software Mark, they stay in the outbox until read by the recipient.
Shaun
Postby Mark Kelly » Fri Dec 28, 2012 11:24 pm
Thanks, didn't know that (slaps forehead).
Mark Kelly
Postby Mark Kelly » Sat Dec 29, 2012 10:39 am
Taken.
Mark Kelly
