ianganderton wrote:N00b question,
I'm just placing an order with c r c for DT Swiss spokes and doing the calculations its recommending odd number lengths but they are only available in even numbers
So if its recommending 275mm spokes should I order 274 or 276??
I'm looking at using DT Swiss revolution spokes with brass nipples
http://www.this link is broken/au/e ... -prod91858" onclick="window.open(this.href);return false;
When using the calculator it seems to allow for stretch when calculating lengths is this the case?
Hi Ian, as with so many things, the answer is "it depends". And it depends on many things ...
1. What ERD are you using? Is it measured, or from the web? Is it based on spoke length to the top of the nipple, or nipple flats? Always measure the rims yourself, they vary.
2. What spoke calculator are you using? An unmodified Spocalc calculates the length to an exact ERD. That's what I would use in your position. Coupled with the above (and reliable hub measurements) you are now really quite accurate.
3. What nipples are you planning on using? Spocalc calculates based on using a 10mm nipple, the length to the top of the nipple. If you are using 12mm nipples (more common) then the ERD/spoke length can be adjusted downwards (-3mm/-1.5mm).
4. DT Swiss Revolutions are a very light spoke. If you are new to wheelbuilding, heavier, building MTB wheels, low spokes counts (<32) or building a rear wheel, I would recommend
against using this spoke. Use something heavier gauge like the Competition (14/15/14G), save some $ and put up with the extra 30-50g. You can thank me later for a more reliable and stiffer wheelset.
If you do use the Revs, note that they will stretch once you get them up to tension, and this needs to be factored into you calculations. On a front or rear driveside, this will be up to about 1mm, so you need to order a 1mm shorter spoke to accommodate. On the rear NDS the tension is lower, so assume they'll stretch only 0.6mm.
Using Comps, half the above stretch assumptions.
I am not aware if the Spoke calculator you are using incorporates stretch. Perhaps the Sapim or DT Swiss online ones do, but I don't use those ..
So there you go, easy isn't it!
Go with 274 if you are happy to take the punt. You'll probably be fine.
