Ghetto methods of chain removal/destroying
TomBikes
Postby TomBikes » Wed Jan 02, 2013 10:45 pm
I just picked up an old malvern star frame from the local tip. After check of the joints and such I decided to turn it into a ss/fixie get around town, don't really care about bike. I just have a slight problem at the moment. I don't have a chain tool and I'm also unable to find the master chain link. Anyone have any ghetto chain removal solutions?
Re: Ghetto methods of chain removal/destroying
Postby bychosis » Wed Jan 02, 2013 11:21 pm
hacksaw or grinder?
hammer sometihing like a spike down between the plates to get them to pop?
high_tea
Postby high_tea » Wed Jan 02, 2013 11:22 pm
I've used boltcutters on an old, rusted-solid chain. The chain wasn't good for anything afterwards, but then again it wasn't good for anything before that either.
drubie
Postby drubie » Thu Jan 03, 2013 1:07 am
I've broken proper chain tools on solidly rusted chains before. Now I hit them with an angle grinder instead.
DavidI
Postby DavidI » Thu Jan 03, 2013 8:48 am
Dremel and cutting disc = hot knife through butter :)
slidetaker
Postby slidetaker » Thu Jan 03, 2013 1:15 pm
Chain breaker tool.....you probably need one for the new chain anyway.
If you insist, put it under a hammer and a hard rock, focus on the rustest link, go crazy, it will break.
HappyHumber
Postby HappyHumber » Thu Jan 03, 2013 2:53 pm
slidetaker wrote:Chain breaker tool.....you probably need one for the new chain anyway.
^^ Like drubie said. If I am not worried about reusing the chain. I will just mash it with a grinder, bolt cutters or a centre punch on one of the rivets. Or any combination of these. I have ruined what I thought were decent chain tools on long dead & rigor-mortified chains before..... but that's not to say you don't need one for cutting a new replacement chain.
- Kym
LG
Postby LG » Thu Jan 03, 2013 3:06 pm
A 'ghetto' method would probably be hacksaw through chainstay. Simple!
LG = Low Gear
uncle arthur
Postby uncle arthur » Thu Jan 03, 2013 4:15 pm
LG wrote:A 'ghetto' method would probably be hacksaw through chainstay. Simple!
Don't joke - I've seen that for real in a redneck fixes bike vid on you tube - and it wasn't a cheap frame the redneck destroyed....... and then "repaired" :roll:
Postby Mulger bill » Thu Jan 03, 2013 4:41 pm
Got any sturdy pointed pliers? One good squeeze in the middle of a pair of outer plates should spring them.
TomBikes
Postby TomBikes » Thu Jan 03, 2013 7:43 pm
Thanks for the replies. I'll try some tomorrow and tell you what works.
Postby toolonglegs » Fri Jan 04, 2013 9:04 am
Two shifters / adjustable spanners clamped down on the side plates... Twist back and forth a couple of times.
Postby jasonc » Fri Jan 04, 2013 10:28 am
please tell me the "repair was done with gaffa tape
uncle arthur
Postby uncle arthur » Fri Jan 04, 2013 10:57 am
The "repair was done by said redneck whittling down a piece of timber to act as a dowel, inserted into the cut ends of the former chainstay, which was then sealed (from memory) wrapped with duct tape.
high_tea
Postby high_tea » Sat Jan 05, 2013 4:15 pm
I can just imagine the redneck dentistry video they made after that repair failed. Moonshine, a cold chisel and some more whittlin' :shock: :shock: :shock:
TomBikes
Postby TomBikes » Sat Jan 05, 2013 7:32 pm
Used a few methods mixed together. First I twisted an inner chain link up, then I wiggled it a little with some pliers, then I finally popped the plate off with a screwdriver and a hammer.
Thanks!
Users browsing this forum: darkhorse75
