Scruffed Carbon Fibre Ultegra Shifter - Reseal w. nailpolish
Shpox
Postby Shpox » Fri Jan 18, 2013 2:42 pm
Hi guys. A friend of mine recently had a fall on his bike and one of the Ultegra shifters got a bit scruffed. Nothing structural, just got rid of the clear coat.
Is exposed CF okay? I thought some clear nail polish might be fine to seal it back up as it's a lacquer but I wasn't sure if the acetone would begin to do more harm than good.
Thoughts? :?:
Saturnstarzz
Re: Scruffed Carbon Fibre Ultegra Shifter - Reseal w. nailpo
Postby Saturnstarzz » Mon Jan 21, 2013 4:33 pm
Clean the area with some acetone or lacquer thinner and apply some clear nail polish. If you want a perfect repair, then several coats will be required, followed by careful sanding with 1000 grit sandpaper.
A very gentle sand then clear coat.
Shpox
Postby Shpox » Tue Jan 22, 2013 12:34 pm
Thanks Lachlan. I contacted Shimano and they said nailpolish would be fine.
Users browsing this forum: hamishm, MSNbot Media
