Is exposed CF okay? I thought some clear nail polish might be fine to seal it back up as it's a lacquer but I wasn't sure if the acetone would begin to do more harm than good.
Thoughts?
Scruffed Carbon Fibre Ultegra Shifter - Reseal w. nailpolish
• Page 1 of 1
Scruffed Carbon Fibre Ultegra Shifter - Reseal w. nailpolishHi guys. A friend of mine recently had a fall on his bike and one of the Ultegra shifters got a bit scruffed. Nothing structural, just got rid of the clear coat.
Is exposed CF okay? I thought some clear nail polish might be fine to seal it back up as it's a lacquer but I wasn't sure if the acetone would begin to do more harm than good. Thoughts?
Re: Scruffed Carbon Fibre Ultegra Shifter - Reseal w. nailpoClean the area with some acetone or lacquer thinner and apply some clear nail polish. If you want a perfect repair, then several coats will be required, followed by careful sanding with 1000 grit sandpaper.
A very gentle sand then clear coat. ![]() 2009 Cannondale CAAD9-5, Single speed GT Avalanche 2.0
Re: Scruffed Carbon Fibre Ultegra Shifter - Reseal w. nailpoThanks Lachlan. I contacted Shimano and they said nailpolish would be fine.
• Page 1 of 1
Who is onlineUsers browsing this forum: trailgumby |
