Page 1 of 1
inflating tubulars
Posted: Sun Jan 20, 2013 8:00 pm
by pistapistar
Hi all, setting up my first set of tubulars. Got a set of Dura Ace C-35's, 2012 model. Putting Conti Competitions on them. Will put stan sealant in the tubulars to seal any small punctures, just wondering the best way to get the tyre back up to full inflation in the event of a puncture. Reviews for the mini pumps aren't great. Would a CO2 cartridge with a regulator on it be the go? What about Vittoria pit stop? Any advise would be greatly appreciated. Thanks
Re: inflating tubulars
Posted: Sun Jan 20, 2013 9:11 pm
by brit_in_oz
If you put Stans in you dont need pit stop, they do the same thing, except pit stop is designed to be used after puncture so (apparently) increases the latex inner tube life. Stans also only lasts a few months before going rubbery and losing its function. As for inflation a pump will get you to 80-90psi with a puch so CO2 is certainly easier, but if its just to get you home 90psi will still do the job.
i would say stans / pit stop work maybe 50% o the time, they are good for thorns and the like, but glass and larger holes they wont seal, i tried one around 2mm from a glass shard and i thought it held, but then 5 min later it went down.
Posted: Sun Jan 20, 2013 9:36 pm
by jacks1071
If you are putting this in as a prevention measure, use Tufo Standard and keep the stans for your mountain bike.
http://www.tufo.com/tufo-tyre-sealant/" onclick="window.open(this.href);return false;
Posted: Mon Jan 21, 2013 6:10 pm
by RunForrestRide
Would you consider taking a spare tub (pre-glued) and changing it out on the road?
Posted: Mon Jan 21, 2013 9:29 pm
by pistapistar
RunForrestRide wrote:Would you consider taking a spare tub (pre-glued) and changing it out on the road?
Prefer not to have to carry a spare. Usually ride in a skinsuit. Thanks for the advise everyone. Saved me the expense of a mini pump! Think I'll try the stan sealant and carry some tufo extreme sealant and a CO2 cartridge. Hope this will keep me rolling.
