Wheelset compatibility - Dura Ace 9000
Postby Weasel » Thu Jan 31, 2013 12:34 pm
Apologies for asking such a naive question, but does anyone know if the latest range of Dura Ace 9000 wheelsets are compatible with superceded Dura Ace running gear, such as 7900 etc?
Or are the latest wheelsets only compatible with the new 11 speed Dura Ace 9000 groupsets etc?
Weasel
by Forum Ads » Thu Jan 31, 2013 1:00 pm
Re: Wheelset compatibility - Dura Ace 9000
Postby MichaelB » Thu Jan 31, 2013 1:00 pm
afaik, 11sp wheels will work on a 10sp setup, but 99% of the time, not the other way around.
MichaelB
Postby scirocco » Thu Jan 31, 2013 2:23 pm
Yes, If you want to run a 10spd cassette on the wider freehub that the 9000 wheels need for 11-spd cassettes, you just fit a spacer. The splines on the freehub are the same.
scirocco
Postby biker jk » Thu Jan 31, 2013 3:33 pm
scirocco wrote:Yes, If you want to run a 10spd cassette on the wider freehub that the 9000 wheels need for 11-spd cassettes, you just fit a spacer. The splines on the freehub are the same.
That is correct. You will have two spacers. The current spacer for a 10-speed cassette plus a 1.85mm spacer for the 11-speed freehub.
biker jk
Users browsing this forum: Haakon
