Pedal and cleat care
Postby dant » Sun May 11, 2008 4:00 pm
I narrowed down a nasty creak to my cleat/pedal. Is there an easy way to determine if the cleat is either worn out or the pedal needs to be looked after a little better? How do most people dial in their pedals with float etc?
I ride a fixie and on the route there are two decent hills. I really give a good yank up on the cleats/pedals to use the fixie's natural momentum to help get up the hills. I have managed to yank my foot out of the pedals a couple of times (and I am almost certain my foot is not twisting out at the ankle to accidentally disengage). Don't know if this is a cause or symptom. It's actually quite unnerving to do it on a fixie and continue pedalling with one foot uphill.
thanks in advance,
adam
dant
by BNA » Sun May 11, 2008 9:48 pm
Postby Hawkeye » Sun May 11, 2008 9:48 pm
My shoes creak something horrible in my SPDs. A little chain lube cures all. 8) I've since read this is something I should be doing anyhoo.
Hawkeye
Re: Pedal and cleat care
Postby Bnej » Mon May 12, 2008 9:01 am
dant wrote:I ride a fixie and on the route there are two decent hills. I really give a good yank up on the cleats/pedals to use the fixie's natural momentum to help get up the hills. I have managed to yank my foot out of the pedals a couple of times (and I am almost certain my foot is not twisting out at the ankle to accidentally disengage). Don't know if this is a cause or symptom. It's actually quite unnerving to do it on a fixie and continue pedalling with one foot uphill.
This is something that can happen with SPDs. I had the same problem with SPDs on my road bike twice then switched to SPD-SLs. The road pedals are far more secure if you're going to be pulling up hard.
Winding up the release tension on your SPDs might help a bit.
Bnej
Postby Mulger bill » Mon May 12, 2008 11:58 am
Worn cleats tend to "rock" around in the bindings, maybe this had something to do with the crook release?
:? 'Bout time for some new cleats, hmmm, maybe shoes too........
Shaun
Postby dant » Mon May 12, 2008 5:51 pm
Thanks guys - a little bit of chain lube fixed the problem beautifully. Going to look into spd-sl's - sounds good.
Adam
dant
Postby rustychisel » Tue May 13, 2008 12:41 pm
get Keywins, you won't pull out of them. And don't try to dance the tango in your cycling shoes, the cleats will last longer.
rustychisel
Users browsing this forum: Mark Kelly
