Latest Reviews and Articles
Will your next bike be Intelligent? ABS and Smart Bike Tech
Vitus Vitesse EVO Disc Review – Speed Machine indeed!
Stretching tubulars
Stretching tubulars
Postby SenorP » Wed Feb 06, 2013 1:38 pm
Re: Stretching tubulars
Postby brit_in_oz » Wed Feb 06, 2013 8:59 pm
- open roader
Postby open roader » Wed Feb 06, 2013 10:04 pm
I'd never stretch tubulars on anything other than a tubular rim , however, it indeed may well be possible to snap them over a clincher rim - too easy to inexpensively purchase an old pair oftrack tubular wheels for the purpose from fleaBay or other online auction sites.
- jacks1071
Postby jacks1071 » Wed Feb 06, 2013 10:28 pm
- scotto
Postby scotto » Thu Feb 07, 2013 7:53 am
jacks1071 wrote:Unless you've got forearms like popeye, you're going to do a much better glue job by pre-stretching them.
this freak needs to pre stretch his tyres a lot. Would probably would have trouble opening the packet !!
these guys just have to look at the tubular and it just surrenders
Postby petal665 » Thu Feb 07, 2013 1:31 pm
Contis maybe, Vittorias, I don't think so.jacks1071 wrote:Unless you've got forearms like popeye, you're going to do a much better glue job by pre-stretching them.
Re: Stretching tubulars - thanks
Postby SenorP » Thu Feb 07, 2013 2:46 pm
Postby petal665 » Thu Feb 07, 2013 2:54 pm
Not so easy!
Postby SenorP » Sat Feb 09, 2013 6:07 pm
First, there are conflicting instructions on how to glue the tyres on.
Vittoria mastik tin just say slam some glue on rim and tyre, wait a bit, put some more on mount the tyres and leave them 24 hours.
Vittoria tyre instructions say 2 to 3 layers of glue, 24 hours between, then a thin layer on rim, mount and wait 24 hours.
I erred on the side of caution which means I'll probably never get them off!
The instructions and videos fail to mention that it's nearly impossible to get the last bit of tyre over the rim without touching the rim...which has uncured glue on it....
It's also a lot harder to get the tyre aligned than all the clever experienced guys on You Tube. It seems you need a fair bit of pressure to make the tub behave. Too little and it winks at you sideways and ends up off centre. Too much and you can't shift it.
Under the heading of "Things I wish I'd known before!"
Dealing with punctures. "Carry a small bottle of sealant," they say. Then when you have a puncture, unscrew the valve and squirt some sealant in, spin the wheel, hit it with the greenhouse gas and ride on.
Er.... The new red valve Vittoria tubs do not have a removable core - the whole valve stem unscrews from a little stub on the tub. A little stub which is now hidden deep behind the rim where I can't get at it to add sealant. I should have added sealant BEFORE I mounted the tyre.
So when the pppssspuncture happens I'll have to resort to replacing the tub with a spare. If I can get the frickkatting tyre off. Or I suppose use 'Pitstop' which is reputed to be only 50% effective.
I did leave 4 cms of unglued tyre opposite the rim, so I'll be able to get a star post in there are lever it off. I hope.
I'll either get used to all this, or in a short time there will be a nice pair of Zeros on EBay! No one said I'd need to tow a trailer with spare tub, tool kit pro mechanic and laundry facilities.
They'd better ride well - tomorrow's the day when the glue has cured and we'll see.
- foo on patrol
Postby foo on patrol » Sat Feb 09, 2013 7:41 pm
Things must have changed big time between then and now.
Foo
Goal 6000km
- open roader
Postby open roader » Sat Feb 09, 2013 9:15 pm
You won't have difficulty getting the tyre off the rim if it's only 3-4 years old. I recently removed a pair of 8 year old glued perished tyres from a pair of wheels I'd purchased - the old glue was very hard and tight and ripped the cloth backer off the tyres when pulled with force. Peeling off a 4 year old tyre with a much heavier glue volume was a snap in comparison......
Getting glue on the rim/brake track irks me a tad too but after gluing up my 3rd pair I resort to adding a few strips of masking tape opposite the valve to cover this inevitablity.
This is your first attempt, just keep the tips and tricks in the forefront of your mind when you glue up your next set, it does become easier with pratice. I enjoy gluing tubulars, it's one thing I can be slow at and yet do a top shelf job of it at the same time.
Postby ironhanglider » Sat Feb 09, 2013 9:41 pm
foo on patrol wrote:Never ever stretched them and quite often raced on them the same day I glued them on, without any problems.![]()
Things must have changed big time between then and now.![]()
Foo
Ahh the days of Clement Red glue, more pressure is better, and not wasting too much glue, or glueing between every other set of spokes when mounting so that you can get the tyre off more easily.
In these modern scientific times good enough is no longer good enough. In the pursuit of better mechanical performance (and an irrational fear of rolling a tyre) we want maximum adhesion rather than what will probably do. Glueing for novices is portrayed as some black art and best done by a 'professional' who charges for the privilege. It is in their interest to make the job sound complex so they can charge more for it. My experience of the modern theory is that it can be mighty hard to remove a well glued tyre without levers, bleeding thumbs and all. It certainly removes any doubt in the corners.
Cameron
- foo on patrol
Postby foo on patrol » Sun Feb 10, 2013 6:06 am
Put the wind up my sails a bit before I did my first glue on but after the first time, I thought, well that wasn't so hard.
myself, couldn't see the point in paying someone else to do it.
Foo
Goal 6000km
- Cyclocross
- Cycling Brands
- Azzurri
- Bianchi
- BMC
- Campagnolo
- Cannondale
- Cervélo
- Colnago
- Focus
- Fuji
- Garmin
- Giant
- Malvern Star
- Merida
- Scott
- Shimano
- Specialized
- SRAM
- Surly
- Trek
- Custom Builders
- Generic Carbon
- Delete all board cookies
The largest cycling discussion forum in Australia for all things bike; from new riders to seasoned bike nuts, the Australian Cycling Forums are a welcoming community where you can ask questions and talk about the type of bikes and cycling topics you like.
