Tyre Pressure Vs Weight
Postby auswi2 » Thu Feb 07, 2013 2:44 pm
Hello,
I am looking to see what other riders around my weight are inflating their front and rear road bike tyres to
I am 5 ft 11 and 104kg
I have been told 100psi to 130psi but my tyres have a max of 120psi
Any suggestions that will still give me tread on the road and still have the correct rolling resistance
auswi2
auswi2
by Forum Ads » Thu Feb 07, 2013 2:57 pm
Re: Tyre Pressure Vs Weight
Postby macca33 » Thu Feb 07, 2013 2:57 pm
I'm heavier than you and use 110 (F) and 115(R) and the rig rolls fine on good roads and shitey ones also.
'dale CAAD10 - Ultegra6700 | Giant Defy 1 - DA7800
macca33
Postby Nobody » Thu Feb 07, 2013 2:57 pm
Nobody
Postby sogood » Thu Feb 07, 2013 4:05 pm
Read all about it from Sheldon Brown. A gospel of knowledge on that site.
http://sheldonbrown.com/tires.html
sogood
Postby toolonglegs » Thu Feb 07, 2013 4:35 pm
Grab some scwhable Durano 25's and run about 90-100 psi... cycling heaven, fast and long lasting.
Postby rkelsen » Thu Feb 07, 2013 7:37 pm
Never go to the maximum. There is no need.
As above, 90 to 100psi is more than enough.
Higher pressures will cause premature wear (and possibly failure) of your equipment.
volutamus scandemus
rkelsen
