changing to compact chain rings on sram
Postby ed muggles » Thu Feb 07, 2013 7:25 pm
i was looking at getting some compact chain rings for the road bike (BMC RM01)that is running sram red.
my question goes some thing like this,
do i need to get a compact crank or can i just get some compact chain rings?
Ed
ed muggles
by Forum Ads » Thu Feb 07, 2013 7:40 pm
Re: changing to compact chain rings on sram
Postby find_bruce » Thu Feb 07, 2013 7:40 pm
Standard cranks 53/39 usually have a 130 bcd (bolt centre diameter) while compact cranks 50/34 have a 110 bcd.
I believe this applies to SRAM red as well.
Long & short you need compact cranks
Postby ed muggles » Thu Feb 07, 2013 7:43 pm
cheers thanks for that
ed muggles
Postby Riggsbie » Thu Feb 07, 2013 7:57 pm
My SRAM Rival compact crank has 130bcd....
Swap it for your SRAM Red crank......I want to go the other way from 50 to 53....
Riggsbie
Postby ironhanglider » Thu Feb 07, 2013 10:48 pm
Riggsbie wrote:My SRAM Rival compact crank has 130bcd....
Presumably this is a mistype. You can't have a compact with a 130bcd spider, the smallest ring possible is a 38T which is not usually considered compact.
Cameron
ironhanglider
