Need Help With Ultegra DI2 Adjusting
Postby auswi2 » Fri Feb 08, 2013 11:37 am
Hello,
I have noticed on my new merida DI2 that when I go down the gears the chain appears to be jumping especially the lower Cogs.
I have watched video's and some may and may not work.
Does anyone on this forum who owns a DI2 advise on a proven way to correctly adjust the RD
I do want to learn to do it myself
auswi2
auswi2
by Forum Ads » Fri Feb 08, 2013 12:22 pm
Re: Need Help With Ultegra DI2 Adjusting
Postby Crawf » Fri Feb 08, 2013 12:22 pm
Page 34.
I'd advise you to count (or write down) the number of times you press the buttons to adjust up or down, that way you can always reverse if you find you have made alignment worse and have an initial reference point.
Crawf
Postby Ross » Sat Feb 09, 2013 5:11 pm
My week old UDi2 has just started doing this, why?
How often is it likely to happen again?
Ross
Postby ozzymac » Sat Feb 09, 2013 5:51 pm
Hi,
I have done over 4000kms with mine and it's never done it.
Might just need a proper first tune up and adjustment etc. I have tuned mine once since I have had it and I was going to do it again today (to wet though) as I am getting a very small annoying chain noise, so hopping a tune will get rid of it.
Sent from my GT-P5110 using Tapatalk 2
ozzymac
Postby jcjordan » Sat Feb 09, 2013 6:39 pm
My first though would be the rear derailiur hanger. Di2 setups push the hanger around quite bit and push it out of alignment. Need a stiffer hanger
James
jcjordan
Postby jimsheedy » Sat Feb 09, 2013 8:01 pm
I typed Ultegra di2 tune into youtube. Watched the video and tuned front and rear. All up took under 5 minutes. No problems since.
jimsheedy
