Tools needed to remove and install crankset?
merlin6014
Postby merlin6014 » Sun Feb 10, 2013 4:55 pm
Hi guys - little confused despite google.
I need to remove my Shimano 105 crankset and BB (shimano pressfit bb86) and install an FSA crankset and BB (megaexo).
What special tools (besides the regular allen keys ect) do I need.
So far I have a Park Tools BBT-9 in the cart along with some grease.
Anything else?
Jesmol
Re: Tools needed to remove and install crankset?
Postby Jesmol » Sun Feb 10, 2013 5:27 pm
I dont think a Megaexo BB will fit in the Pressfit frame.
merlin6014
Postby merlin6014 » Sun Feb 10, 2013 5:30 pm
Jesmol wrote:I dont think a Megaexo BB will fit in the Pressfit frame.
I damn well hope it does otherwise I'm out $$$$. Its a Scott Foil 40 if that helps. As far as I can tell from the FSA site they are compatible.
Jesmol
Postby Jesmol » Sun Feb 10, 2013 5:42 pm
Megaexo is a screw in BB, unless you can get frame mount adapters (fsa may make them) I dont think it will fit
Looks like you need a different BB, the std Megaexo wont work, either
http://www.wiggle.com.au/fsa-energy-and-gossamer-mega-exo-bb-adapters/
or
http://www.wiggle.com.au/fsa-sl-k-light-and-team-issue-mega-exo-bb-adapters/
merlin6014
Postby merlin6014 » Sun Feb 10, 2013 6:32 pm
But my frame takes a bb86 bottom bracket and megaexo is compatible with that according to fsa. Those links are for bb30.
Edit - to explain further i am replacing the entire bb with a ceramic fsa one (comes with the crank) not just trying to use my shimano pressfit with the fsa.
mitzikatzi
Postby mitzikatzi » Sun Feb 10, 2013 7:07 pm
If you know what bike you have and what parts you need.
Go to the Park tools site for "how to do the task info". Then list the tools you need.
Jesmol
Postby Jesmol » Sun Feb 10, 2013 7:26 pm
merlin6014 wrote:But my frame takes a bb86 bottom bracket and megaexo is compatible with that according to fsa. Those links are for bb30.
Yes, but does the bracket you have with the cranks have a thread ? there is no thread on a BB86 pressfit. They do make a Pressfit FSA BB as per my wiggle links.
Postby Mulger bill » Sun Feb 10, 2013 7:28 pm
This.
The crankset will swapover fine but you need to buy the appropriate PressFit cups, your frames BB shell does not have threads to screw the MegaExo into.
merlin6014
Postby merlin6014 » Sun Feb 10, 2013 7:47 pm
OK I think I believe you now :D
But those links you posted both say "These adapters enable you to fit your Mega-Exo chainsets to BB30 frames."
I dont have a bb30 frame
merlin6014
Postby merlin6014 » Sun Feb 10, 2013 8:04 pm
Jesmol
Postby Jesmol » Sun Feb 10, 2013 8:30 pm
Which crankset have you got ?
merlin6014
Postby merlin6014 » Sun Feb 10, 2013 8:32 pm
Jesmol wrote:Which crankset have you got ?
Bike came with a Shimano 105 5700 crankset and I am trying to fit a FSA K-Force Light Double crankset.
Jesmol
Postby Jesmol » Sun Feb 10, 2013 8:35 pm
Then that looks like the right stuff. As for tools, sorry never worked with press fit stuff alll of my frames have been BSA thread
Postby Mulger bill » Sun Feb 10, 2013 10:19 pm
You'll need a headset press with the adaptors for PF BBs OR, the MacGyver route of a long enough, beefy bolt, nut and large enough washers.
Safest option would be to take the bare frame and BB to a trusted LBS, a two minute job.
Postby find_bruce » Sun Feb 10, 2013 11:04 pm
Maybe I am the one confused, but if he has a 105 crank with BB 86 bearings, doesn't that mean he can leave the BB86 bearing in and fit the FSA crank into it ?
Jesmol
Postby Jesmol » Mon Feb 11, 2013 11:10 am
find_bruce wrote:Maybe I am the one confused, but if he has a 105 crank with BB 86 bearings, doesn't that mean he can leave the BB86 bearing in and fit the FSA crank into it ?
No, axle sizing is similar but not the same.
Users browsing this forum: 10speedsemiracer
