Loose fork/steerer tube.
Postby Pravda » Fri Mar 15, 2013 4:34 pm
I'm getting a little movement through my front wheel and fork which I think is because the fork isn't done up tight enough through the headtube.
I initially thought it was a result of cone bolts on the axle not being done up tight enough but I've checked them and they're done up tight enough.
Anyone have any thoughts on how to solve the problem?
2011 Bianchi Via Nirone Veloce
Puegeot Aneto 105
Kona Jake the Snake CX
Pravda
by Forum Ads » Fri Mar 15, 2013 4:41 pm
Re: Loose fork/steerer tube.
Postby Nobody » Fri Mar 15, 2013 4:41 pm
Is your headset threaded or threadless (Aheadset) style?
Try the link below. It may help.
http://www.parktool.com/blog/repair-help
Nobody
Postby Pravda » Fri Mar 15, 2013 4:55 pm
It's threadless. I'm thinking that might be the go.
Puegeot Aneto 105
Pravda
Postby HLC » Sat Mar 16, 2013 5:46 pm
loose headset imo.
HLC
Postby jacks1071 » Sat Mar 16, 2013 8:55 pm
Loosen the stem bolts, do up the top cap bolt to tension the headset then tighten the stem bolts.
If you arn't really comfortable with this get it done by a professional.
If its been loose for a while the fork should be removed, headset bearings and frame cups checked, steerer inspected for damage before re-assembly.
jacks1071
Users browsing this forum: foo on patrol
