sliding seatpost
Chuckles1981
sliding seatpost
Postby Chuckles1981 » Tue May 20, 2008 12:36 pm
anyone have any tips advice on fixing a sliding seatpost???
when i go over hard bump it happens :x
NOW
Trek 7.5 FX
Jamis Ranger 3.0
NEXT
Giant Trance X1
LuckyPierre
Postby LuckyPierre » Tue May 20, 2008 12:42 pm
road v off-road?
quick release v bolt?
carbon v alloy?
Chuckles1981
Postby Chuckles1981 » Tue May 20, 2008 2:27 pm
its an MTB on clamps and its alloy
NOW
Trek 7.5 FX
Jamis Ranger 3.0
NEXT
Giant Trance X1
tallywhacker
Postby tallywhacker » Tue May 20, 2008 2:29 pm
blue loctite between the seatpost and seat tube before tightening. Leave it to dry overnight.
Shard
Postby Shard » Tue May 20, 2008 3:43 pm
If it's 1-2mm too small try wrapping a cut coke can (cylinder bit) around the bit being clamped, that should keep it in place.
Shard
winona_rider
Postby winona_rider » Tue May 20, 2008 9:01 pm
don't tell anyone i told you this...but some packing tape once or twice around does the trick. BUT! you gotta clean it out and replace the tape every 2 or 3 weeks depending on how often you ride.
in saying this i STRESS i got sick of this pretty quick and bought a seat post 0.2 mm thicker for 10 bucks and it has been freakin awsm. werd
alchemist
Postby alchemist » Tue May 20, 2008 9:28 pm
Chuckles1981 wrote:its an MTB on clamps and its alloy
Not a Scott is it?
LuckyPierre
Postby LuckyPierre » Thu May 22, 2008 9:34 am
The big tip underlying the responses so far is - check that you've got the right size seat post - 0.2mm makes a big difference, especially for quick release clamps.
twowheels
Postby twowheels » Fri May 23, 2008 6:55 pm
Could be the contoured plastic shim/washer that the QR clamps onto has split, like my plastic one did. Kept retightening the thing before I realised what had happened.
I replaced mine with a metal shim/washer from an old brake assembly, the little part that make sthe brake sit "flat" on the brake bridge or fork ... hasn't slipped since.
Users browsing this forum: Cycleops70, Exabot [Bot]
