105 casette chain skipping
hackattack
Postby hackattack » Sat May 11, 2013 10:44 pm
Hi guys,
I wanted to use an old 105 cassette for a single speed. Iv got two chains but when I set them up with chain tension they reach a point after about 1/2 a revolution where they lock up, the chain seems to be not sitting correctly on the 105 cs-5600 cassette.
I was wondering if this is because of the ratio of my rear and front cassette or because of the size of chain?
ironhanglider
Re: 105 casette chain skipping
Postby ironhanglider » Sat May 11, 2013 11:14 pm
Chainrings are hardly ever concentric.
Sheldon Brown wrote:Centering Chainwheels
The chain tension on a fixed gear is quite critical, and is regulated by moving the rear axle back and forth in the forkends. If the chain is too tight, the drivetrain will bind, perhaps only at one angle of the pedals (chainwheels are not usually perfectly concentric). It should be tight as it can be without binding. If the chain is too loose, it can fall off, which is quite dangerous on a fixed gear.
Set the rear axle so that the chain pulls taut at the tightest part of the cranks' rotation. One at a time, loosen up each of the stack bolts, and tighten it back just finger tight. Spin the crank slowly and watch for the chain to get to its tightest point. Strike the taut chain lightly with a convenient tool to make the chain ring move a bit on its spider. Then rotate the crank some more, finding the new tightest spot, and repeat as necessary.
This takes a little bit of your hands' learning how hard to hit the chain, and how loose to set the stack bolts, but it is really quite easy to learn.
Tighten up the stack bolts a bit and re-check. Tighten the stack bolts in a regular pattern, like the lug nuts on a car wheel. My standard pattern is to start by tightening the bolt opposite the crank, then move clockwise 2 bolts (144 degrees), tighten that one, clockwise 2 more, and so on. Never tighten two neighboring bolts in a row. You may prefer to go counterclockwise, but try to get in the habit of always starting at the same place and always going the same way. This reduces the chances of accidentally missing a bolt.
Once you have the chainrings centered and secured, adjust the position of the rear axle to make the chain as nearly tight as possible without binding. Notice how freely the drive train turns when the chain is too loose. That is how freely it should turn when you are done, but with as little chain droop as possible.
Cassettes are designed to change gears. If your chainline isn't straight then it might be trying to change gears for you.
Sheldon on Chainline
I presume the chains are a match for the cassette? (ie not a 1/8" chain on a 10spd cassette)
Cameron
hackattack
Postby hackattack » Sat May 11, 2013 11:24 pm
That's what im not sure about, i found this cassette on a wheel on the side of the road, the chains I have are from two 1980 bikes. Im waiting for some spacers in the mail so I cant adjust the chain-line only with the different gears of the 105 cassette currently.
I bought a 1/8" chain for a different bike, it looks different than the chains iv tried, I haven't measured anything but it looks like the chain is a tiny bit smaller than the 105 cassette and after 6-7 links it begins to raise out of the cassette's teeth
high_tea
Postby high_tea » Sun May 12, 2013 3:54 pm
Mmmm, I wouldn't imagine that mismatched widths would be the issue.
Happy to be corrected here, but I think that every 105 sprocket ever made was half-inch pitch, so I doubt that there's any issue there.
Too-narrow sprockets + too-wide chains isn't generally a big deal. I've run 3/32" stuff with 1/8" chains without hassles.
I can't see how the sprocket could be too wide either; I don't expect 105 sprockets wider than 3/32" actually exist. I did once have a situation that was similar to what you describe. It turned out I was trying to use a 3/32" chain on 1/8" sprockets :oops: :oops: :oops: . Chains from 1980 would be 3/32", I would imagine, so that doesn't sound like the problem.
Worn sprocket + new chain, maybe? If you've got plenty of tension on the chain, that'd make the problem show up more readily. Anyway, assuming an okay chainline and compatible sprocket/chain/chainring I'd blame the following, in order of likeliness:
worn chain
worn sprocket
worn chainring
ironhanglider
Postby ironhanglider » Sun May 12, 2013 6:08 pm
high_tea wrote:Mmmm, I wouldn't imagine that mismatched widths would be the issue.
worn chain
worn sprocket
worn chainring
I agree with you regarding the pitch, I think 10mm was restricted to Dura-Ace :wink: . I also agree that 80's chains are likely to be 3/32", 9 speed didn't come around until the 90s and came with 5/64" chains.
Normally with single cogs a too wide chain is not an issue (do it myself), however my understanding of the situation is that hackattack is using the cassette as is and not separating the cogs. I was thinking that hackattack is using a 3/32" chain on a 9 (or 10) speed cassette and the extra width means that the chain is catching on the shifting ramps of the next bigger cog which is trying to shift gears for him. In that case he'd either have to get a matching chain, or do some cassette surgery to change the order of the cogs and spacers so that there are two spacers on either side of the cog that's in use to create extra space.
Cameron
high_tea
Postby high_tea » Sun May 12, 2013 6:13 pm
Ah, see what you mean. Good point. That hadn't occurred to me.
Users browsing this forum: Bing [Bot], bychosis
