Latest Reviews and Articles
Will your next bike be Intelligent? ABS and Smart Bike Tech
Vitus Vitesse EVO Disc Review – Speed Machine indeed!
Tick/click noise from BB/Crank every rotation
- Pravda
Postby Pravda » Mon May 20, 2013 3:57 pm
I've checked the chain ring bolts and the pedals and they're all tight. The more power I put into the pedals the louder it is, down to just spinning and I can't hear it at all.
Any thoughts on the source or remedy? It's a BB30 with an FSA crankset.
Cheers.
Puegeot Aneto 105
Kona Jake the Snake CX
Re: Tick/click noise from BB/Crank every rotation
Postby r2160 » Mon May 20, 2013 4:08 pm
Dont ask how I know
Glenn
"Pain is temporary. It may last a minute, or an hour, or a day, or a year, but eventually it will subside and something else will take its place. If I quit, however, it lasts forever" Lance Armstrong
- Pravda
Postby Pravda » Mon May 20, 2013 4:15 pm
Sent from my GT-I9300 using Tapatalk 2
Puegeot Aneto 105
- familyguy
Postby familyguy » Mon May 20, 2013 4:25 pm
- bychosis
Postby bychosis » Mon May 20, 2013 4:41 pm
- Slvr32gtr
Postby Slvr32gtr » Mon May 20, 2013 4:53 pm
Worth checking out and ruling out anyway!
- Pravda
Postby Pravda » Mon May 20, 2013 5:04 pm
bychosis wrote:Had a nstry click sound from a worn BB before. Only diagnosed it as that after checking all manner of other points, including suspension bearings. Only happened under load and usually in the same spot. Took the chain off and could feel the rumble in the BB.
I'm hoping that's not the case as the bike is only 6 months old, it has been ridden in some wet weather over the last week or so though.
Puegeot Aneto 105
- Tim
Postby Tim » Mon May 20, 2013 5:30 pm
The press fit cartridge bearings often move under load inside the frame/bearing housing.
Unless the frame/bearing tolerances are precisely machined the bearings are prone to movement. It is a very common problem with BB30. I have this system on one of my bikes and it has been a constant PITA.
The solution is to remove or replace the existing bearings and refit them using Loctite #641(I think, but check for sure) to effectively glue them in place and prevent the movement and noise.
I wouldn't recommend BB30 to my worst enemy. I won't get caught again. BB30 is a very poor design.
- FXST01
Postby FXST01 » Mon May 20, 2013 5:35 pm
- scotto
Postby scotto » Mon May 20, 2013 5:37 pm
- nickobec
Postby nickobec » Mon May 20, 2013 5:38 pm
- DoogleDave
Postby DoogleDave » Mon May 20, 2013 5:43 pm
I too had a very similar issue and could barely hear it when turning the cranks slowly by handbut when loading the cranks during riding the creak began getting louder.
I had this issue on my Felt about 3-6 months from new and took it back to the shop.
They pulled the BB apart and put it back together again and it's been fine for the last 5000 km's.
Unfortunately, a design flaw that most frame manufacturers don't adhere to very well (re: very tight tolerances)
Dave
Postby wicksey » Mon May 20, 2013 5:44 pm
- bychosis
Postby bychosis » Mon May 20, 2013 6:50 pm
Postby macca33 » Mon May 20, 2013 7:33 pm
Mine started after a big wet ride, so it may have been due to water ingress, I reckon.
- Pravda
Postby Pravda » Mon May 20, 2013 8:52 pm
However I checked QR skewer (it's tight) and pedals which are fine.
I gather I need a special tool to remove a BB30 so I guess if the noise comes back, which I think it will, I'll invest in one and have a poke around.
Puegeot Aneto 105
Postby macca33 » Mon May 20, 2013 11:22 pm
Pravda wrote:OK, the noise mysteriously disappeared for my ride home from work today.
If it is the FSA SL-K crankset, no - just use a 10mm (as I recall???) Hex wrench / socket and turn it anti-clockwise - the crank arm self-extracts. To remove the BB30 bearings, you will need a BB bearing punch-out tool jigger and to install, a BB bearing press tool. I reckon if you take the crank and seals off, give it a good clean and grease, you may be right without changing the bearings - worth a shot anyway.
- Pravda
Postby Pravda » Mon May 20, 2013 11:30 pm
Puegeot Aneto 105
- Pravda
Postby Pravda » Fri May 24, 2013 12:58 pm
I've got a 10mm alen key and I think that means I should be able to get the crank off.
Is it worth loading it up with grease and letting the LBS deal with it next week?
Puegeot Aneto 105
- simonn
Postby simonn » Fri May 24, 2013 1:52 pm
Pravda wrote:I checked QR skewer (it's tight)
Tight enough? Grease the dropouts and then put the rear wheel on again tightly. Had similar problem with my CX and this solved it.
Postby Gerry.M » Fri May 24, 2013 2:20 pm
Pravda wrote:Alright I've narrowed this down to the BB, I'm going to leave the proper fixing of it to the LBS next week but I've got a race on this bike tomorrow, anyone have any ideas on a quickfix?
I used to get the same after riding in rain/dirt. Click, click with every rotation with power.
Got the BB replaced with a sealed unit (apparently the old one wasn't) and been happy days since.
As a quick fix, I used to clean as much grit out of it as possible and pump some oil or grease in there, but that was only a temporary solution.
- Pravda
Postby Pravda » Fri May 24, 2013 2:34 pm
Gerry.M wrote:I used to get the same after riding in rain/dirt. Click, click with every rotation with power.
Yeah might do that, I've got it booked in for a replacement on Tuesday.
Puegeot Aneto 105
- Pravda
Postby Pravda » Fri May 24, 2013 10:40 pm
Puegeot Aneto 105
Postby rikwall » Wed Oct 09, 2013 12:00 pm
- im_no_pro
Postby im_no_pro » Wed Oct 09, 2013 1:54 pm
nickobec wrote:Last time I had something similar, it was a loose cleat bolt
Wish I had read this a week ago..... took me ages to figure out that was my problem also
- Cyclocross
- Cycling Brands
- Azzurri
- Bianchi
- BMC
- Campagnolo
- Cannondale
- Cervélo
- Colnago
- Focus
- Fuji
- Garmin
- Giant
- Malvern Star
- Merida
- Scott
- Shimano
- Specialized
- SRAM
- Surly
- Trek
- Custom Builders
- Generic Carbon
- Delete all board cookies
The largest cycling discussion forum in Australia for all things bike; from new riders to seasoned bike nuts, the Australian Cycling Forums are a welcoming community where you can ask questions and talk about the type of bikes and cycling topics you like.
