for the sake of it
bollo
for the sake of it
Postby bollo » Fri Jun 21, 2013 9:23 pm
ok i have a 2012 Sultura Evo 905 Merida i was thinking of upgrading to DI2 Ultegra but after chating to a few LBS i have decided to upgrade my rims instead as i would prob get more gain from it.
I don't race just ride for fitness, i rode with others & we are very competitive within our group rides so if this helps me a little then great i have Fulcrum Comp rims atm (standard fitment) & am thinking of up grading to RS80 C24 carbons can get them for $600 is this the right place to upgrade ?
2013 Cube Lightning HPC SL Race
2012 Merida Scultura Evo 905
Re: for the sake of it
Postby ldrcycles » Fri Jun 21, 2013 9:52 pm
From the limited understanding I have of Fulcrums, the Comp is roughly equivalent to Mavic Aksiums or Shimano R500s (so a step above the very common entry level Shimano hubs/Alex rims wheelsets), if that is the case then you will notice a BIG difference going to the RS80s. I have a set that has seen at least 3,000kms so far, no issues at all so far, they feel much better for accelerating and climbing, and a lot stiffer and more 'direct'.
I wouldn't mind getting some deeper rims though for going fast on the flat.
bollo
Postby bollo » Fri Jun 21, 2013 11:09 pm
ok thats great feedback cheers so whats the difference in say 24mm deep rims to 35 mm deep rims to 50mm deep rims ?
Postby Duck! » Fri Jun 21, 2013 11:42 pm
Weight vs. aero. Deeper rims are heavier, no escaping that fact, because more material has to go into building them. As a result, they don't climb as well, because the inertia of extra rotating mass requires more effort to keep moving upward, which works against you. However, on the flat the weight is less of a concern, as the deeper profile makes a smoother hole through the air, and once up to speed will maintain that speed better. On the other side, deep rims can be a handful in strong crosswinds, especially with a light rider on board.
Pick your rims to suit your riding. If you're doing a lot of hill work, go shallower. If you're mainly a flat rider, and not overly bothered by crosswinds, go deeper. If you do a bit of everything, or are a flyweight who gets chucked around a lot by strong winds, play the middle ground & go the 35s.
justanewbie
Postby justanewbie » Sat Jun 22, 2013 6:49 am
$600 for RS80's is a little steep, have a look around but I'm pretty sure I've seen them online for ~$500. They're great wheels, and give surprisingly low drag numbers (similar to other brands dodgy aero wheels) for the depth.
antipodean
Postby antipodean » Sat Jun 22, 2013 8:02 am
2013 Oppy SL
2013 Boardman CX Pro
2012 KHS Yuma 29er
Postby ldrcycles » Sat Jun 22, 2013 2:23 pm
What Duck! said. I got my RS80s new off ebay for $500 from a bloke in Victoria. A local shop quoted me $1100 :shock: .
warthog1
Postby warthog1 » Sat Jun 22, 2013 5:41 pm
From another thread
In summary, wheels account for almost 10% of the total power required to race your bike and the dominant factor in wheel performance is aerodynamics. Wheel mass is a second order effect (nearly 10 times less significant) and wheel inertia is a third order effect (nearly 100 times less significant). The best wheels in terms of performance are the ones that are lightweight, aerodynamic, don’t rub brake pads and are strong enough to get you to the finish line. The problem with these high performance wheels, though, is that they sacrifice on the other two key variables important in wheel selection: durability and price. High performance wheels are neither durable nor cheap. Nothing is ever easy, is it?
http://www.biketechreview.com/index.php/reviews/wheels/63-wheel-performance
Aero trumps weight
foo on patrol
Postby foo on patrol » Sat Jun 22, 2013 5:48 pm
For my mind, I would rather a set of wheels that spun freely than a set that was light or heavy and laboured to rotate for any length of time. :wink:
Foo
Goal 6000km
RideLikeTheWind
Postby RideLikeTheWind » Sat Jun 22, 2013 8:34 pm
I bought a pair of Fulcrum Racing 3 from bike-discount.de for about $500 delivered. They are absolutely awesome and I'm only using them for fitness etc. They have a big range and good prices.
Joe
LM324
Postby LM324 » Sat Jun 22, 2013 11:25 pm
Is there anything in particular with your wheels that you don't like? If you are not racing and just riding for fun, just keep riding. You don't necessarily need to upgrade you wheels but if you want to then go ahead.
bollo
Postby bollo » Wed Jul 10, 2013 7:23 am
well i got the new ultegra crankset fitted & they said you will feel the difference in riding & i sort of though year whatever, but i can the bike feels more responsive when i pedal hard & i seam to be able to keep a higher cadence for longer is this all in my head or is this the effect a lighter stiffer crankset offers ?
oh & they look trick to :D
bollo
Postby bollo » Wed Jul 10, 2013 7:25 am
prob should have mentioned i went from BB30 FSA cranks to these Ultegra not sure of the arm length of the FGSA but these ultegra i chose 172,5 mm , we used a scram press in insert & an ultegra bottom bracket , feels so smooth now to
Mozzar
Postby Mozzar » Wed Jul 10, 2013 2:26 pm
As others have said, deaper rims are heaver and therefore you need more energy to spin the rim and if your not going in a straight line (not stopping at traffic lights) for long periods then you might get away with the aero affects of the deeper rims, I would go for a lighter shallower rim so i don't waste energy spinning the rim up to speed. Alot of cheaper carbon rims are actually carbon/alloy and the carbon is only a thin overlay to creat the deep look and aero affect, but mostly just adding unecessary weight for no reason.
Users browsing this forum: DrShifty, Duck!, Tamiya
