Tell Me The Difference Please
foo on patrol
Postby foo on patrol » Sat Jun 22, 2013 5:37 pm
Ok, I want to know if there is any difference, other than the name = Ultegra, Durace, 105, Tiagra and Sora in the clusters oh sorry cassettes as they are called now? :?
Now I want to know if, they are able to be use with the same chain. I currently have Durace shifters (front and back) with Rotor Q rings. Seeing as I don't do many Ks and won't be able to for another 3-4yrs if the lower end stuff will be fine. I just bought some wheels off Redsonic and need to put a cassette/cluster on these wheels. :wink:
If it was the same as when I was racing in the 70/80s I would be fine but things are so different now with the gear. :? :(
Foo
Goal 6000km
warthog1
Re: Tell Me The Difference Please
Postby warthog1 » Sat Jun 22, 2013 5:55 pm
I buy sram clusters for use with my 10 speed shimano and just get the cheaper ones. The expensive ones are just a bit lighter, a couple of mouthfulls of water :)
As far as shimano goes the dura ace has titanium sprockets for the 4 largest cogs in the cluster which may be why they are so expensive. I've never tried them 105 and ultegra have been fine and I can buy 3 or 4 of them for the price of one dura ace cluster. I get the 28\11 sram pg 1050 or 1070's now and they shift as well or better than the shimano I reckon.
open roader
Postby open roader » Sat Jun 22, 2013 5:59 pm
I had need to replace a 105 cassette and did so with Ultegra 6700 cassette as only Ultegra offered the ratios i wanted but there was no chain compatibility issues at all - out with one and in with the other........ At the same time I also had the option to purchase D.A. over Ultegra and was told by LBS that D.A. was lighter weight, but offered no better shifting than a correctly tuned 105 or Ultegra set up so chances are D.A. cassettes use Ti on some cogs to shed weight..........
Postby ldrcycles » Sat Jun 22, 2013 6:49 pm
You can also get SunRace cassettes (Taiwanese company that bought out Sturmey Archer a few years back). I used a 9spd one on my old Scott and it worked fine.
Postby Duck! » Sat Jun 22, 2013 7:15 pm
The differences are in the materials used, and the manufacturing processes, resulting in lighter, stronger & harder-wearing components the higher up the range you go. Dura Ace cassettes have several sprockets made from titanium, while all others are all steel. All levels of components with a given number of gears are compatible with each other, but you'll strike problems trying to mix 9-speed chains/cassettes with an otherwise 10-sp. group & vice versa.
foo on patrol
Postby foo on patrol » Sat Jun 22, 2013 8:01 pm
Thanks all, it a bugger trying to come to grips with all the new stuff. :oops:
Foo
Goal 6000km
foo on patrol
Postby foo on patrol » Sat Jun 22, 2013 8:04 pm
warthog1 wrote:I buy sram clusters for use with my 10 speed shimano and just get the cheaper ones. The expensive ones are just a bit lighter, a couple of mouthfulls of water :)
Um dumb question time. I thought you needed Sram specific hubs, to be able to use them or have I been reading some threads wrong? :? be gentle with me now. :mrgreen:
Foo
Goal 6000km
Postby ldrcycles » Sat Jun 22, 2013 8:15 pm
Nope, SRAM and Shimano use the same freehub spline pattern, Campagnolo's is different.
(disclaimer, i'm not actually sure that SRAM and Shimano freehubs are exactly the same, but the cassettes are interchangeable, I used a SRAM cassette for a while).
Postby Duck! » Sat Jun 22, 2013 8:43 pm
foo on patrol wrote:Um dumb question time. I thought you needed Sram specific hubs, to be able to use them or have I been reading some threads wrong? :?
Only for XX1 MTB stuff. All other SRAM cassettes use the Shimano pattern.
foo on patrol
Postby foo on patrol » Sun Jun 23, 2013 7:13 am
See, told ya it was dumb question time. :lol: Thanks. :)
Foo
Goal 6000km
pjt
Postby pjt » Fri Jun 28, 2013 2:14 pm
One thing to note. If your Shimano-compatible wheelset/rear hub has an aluminium freehub body, you want a cassette with as many cogs as possible on a spider-carrier - and generally this is the more expensive groupset cassette. If it's lots of individual cogs (which tend to be the case at the Tiagra-ish level) each cog will bite into the freehub body and start chewing up the aluminium.
It's not a disaster (you can use a file, or Dremel tool to file the chewed up bits out) but it makes getting cassettes on and off a real bear, and in general isn't a great thing to do to your fancy expensive freehub/wheelset.
Not an issue with Campag freehub bodies, or the short lived "deep spline" 10 speed Shimano freehub body (which was only on their 7800 hubs and a select few 3rd party wheelsets). Haven't seen 11sp freehub bodies so don't know if this issue persists - anyone know?
biker jk
Postby biker jk » Fri Jun 28, 2013 2:21 pm
pjt wrote:One thing to note. If your Shimano-compatible wheelset/rear hub has an aluminium freehub body, you want a cassette with as many cogs as possible on a spider-carrier - and generally this is the more expensive groupset cassette. If it's lots of individual cogs (which tend to be the case at the Tiagra-ish level) each cog will bite into the freehub body and start chewing up the aluminium.
Not an issue on Shimano wheelsets since the freehub is steel or titanium (Dura-Ace). Also really not an issue with aluminium alloy freehubs if you tighten the cassette to specification.
Postby Duck! » Sun Jun 30, 2013 11:55 pm
pjt wrote:Haven't seen 11sp freehub bodies so don't know if this issue persists - anyone know?
Shimano 11-sp freewheel bodies have reverted to the traditional shallow spline, it's just a longer body to fit the extra gear on. As with previous generations of Dura Ace hubs, the body is titanium, so sprocket bites are avoided, but third party manufacturers are using aluminium, which will suffer the same fate in years to come as 11-sp. trickles down the ranks (as it is, I think the biggest six sprockets in Dura Ace cassettes are mounted to carriers, the rest are individually mounted).
Users browsing this forum: bychosis
