105 brifter parts
Dadrock
105 brifter parts
Postby Dadrock » Mon Jul 01, 2013 2:02 pm
So I've pulled my older 5500 brifters out for a winter bike project, to find that I've lost one fo the t-bolts that is part of the clamp band on the brifter.
It's the bolt on the right in the parts labelled '7' in this diagram on the Shimano tech docs site:
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-5600-2441A_v1_m56577569830646710.pdf
So, does anyone have one rattling around in thier parts box, or know of a good source for these small parts? I'll be hitting the LBS up this weekend, but I thought I'd ask here first :wink:
cheers, Martin
"You make pigs smoke. You feed beef burgers to swans. You have big sheds, but nobody's allowed in..."
Saturnstarzz
Re: 105 brifter parts
Postby Saturnstarzz » Mon Jul 01, 2013 7:47 pm
I lost my screw part ages from my 105 brifter ages ago.
My solution was to use the same size bolt that I had lying around from my old MTb rotors.
Im sure most LBS would sell the clamp's and screw assembly's all in one kit
Fellow forum member quangvong might be able help you, rebuilds brifters all the time. send them a Pm
Postby QuangVuong » Mon Jul 01, 2013 10:27 pm
That part is something that the older brifters dont use. They have a bolt in the lever, and the clamp band is a nut.
The part youre finding is prob best found at the LBS or eBay. I bought some 5600 levers for cheap, but missing a name plate and the clamp band and bolt. I'll be next in line for one if anyone has it.
Postby Duck! » Mon Jul 01, 2013 10:42 pm
I'll have a dig around, I may have what you need.
Dadrock
Postby Dadrock » Tue Jul 02, 2013 11:22 am
Cheers all for the responses. I'll be down the LBS this weekend and see if they have any lying around.
If I come across a stash of these I'll be sure to let youse all know!
martin
HappyHumber
Postby HappyHumber » Tue Jul 02, 2013 2:31 pm
*mumble*grumble*
I am in similar boat for a pair of 5500 series brakes, in otherwise great condition. Lost one of the cable pinch bolts. Seems a different threading than all the other ratty, misc Shimano calipers I have in my spares box. :evil:
- Kym
Users browsing this forum: Ivanerrol
