how often do you need to adjust gears
schroeds
Postby schroeds » Fri Jul 05, 2013 10:06 pm
On a top groupset like Sram Red, how often should it be necessary to adjust the gear changing?
Not so much a cyclist...more of a sit down comedian
Strawburger
Re: how often do you need to adjust gears
Postby Strawburger » Fri Jul 05, 2013 10:43 pm
With a top of the line groupset, during your weekly clean and maintenance routine :wink:
It all depends on how good your cables are, the weather conditions during the rides and how the bike is stored. All of my bikes get a tweak only when necessary and generally 1000kms. The race bike gets the royal treatment and only needs adjustment a week or two after new cable changes. This is generally between 3000-5000kms or 12 months.
n=10 (2013 & 2004 roads,2010 track,2x 2009 foldups,1990 hybrid,1992 trainer,2007 rental,1970's step through,1980's zeus)
Postby Duck! » Sat Jul 06, 2013 2:23 am
Being SRAM, almost constantly. Shimano & Campag require retuning very infrequently.
ozdavo
Postby ozdavo » Sat Jul 06, 2013 6:59 am
Be aware SRAM bashing is a sport online. Weather or not it is justified or not I don't know, but I've had no problems with my SRAM Force, and change cables about every 6 - 12 months, and generally don't retune I between changes.
Sent from my iThingy using Tapatalk
nescius
Postby nescius » Sat Jul 06, 2013 8:09 am
I've done almost 3000km on my race bike that is equipped with SRAM Red, no adjustments required so far.
Scott Spark 900 RC | Giant Trance | Giant Reign 3 | Trek Madone 4.5 | Look 695 SR ipack | Fuji Track 1.1
queequeg
Postby queequeg » Sat Jul 06, 2013 8:48 am
My SRAM Apex only needs adjusting when I either change the cables or the cassette, and even then it is only a minor adjustment.
GeoffInBrisbane
Postby GeoffInBrisbane » Sat Jul 06, 2013 9:32 am
Duck! wrote:Being SRAM, almost constantly. Shimano & Campag require retuning very infrequently.
Completely the opposite of my experience. Shimano I find to go out of adjustment frequently. I hardly ever have to readjust on Red.
Veloviewer
MS-DOS Phone. For when you want it done right.
schroeds
Postby schroeds » Sat Jul 06, 2013 12:04 pm
Haha, thanks for that very unhelpful contribution Duck, I should have said my Sram Red has gone 4,500 kms without needing adjustment....it does need a tune now though.
Duck....are you there Duck?:grin:
Sent from my HTC Desire S using Tapatalk 2
macca33
Postby macca33 » Sat Jul 06, 2013 12:56 pm
After setting them up and making initial minor adjustments during / after a ride, I haven't had to adjust my gears on either bike for a long time (1000 & 3000Km, respectively). Shimano DA7800 & Ultegra6700 used and I don't have any of those barrel adjusters fitted to my cables - just straight out of the levers to the respective derailleurs.
Marty Moose
Postby Marty Moose » Sat Jul 06, 2013 1:40 pm
not once since I've had di2 :)
Postby Duck! » Sat Jul 06, 2013 5:05 pm
OK, so I was exaggerating slightly, but I've found SRAM to be more finnicky than the other two.
They'll all need a bit of a tweaking for a short while after fitting new cables as they stretch & settle in, but after that they're good for a long time. The most stable of the lot are Shimano with the "clothesline" gear cables - set & forget for 10,000+km (but check the cables periodically, 'cos they do fray inside the shifters!). With fewer curves in the cabling, the friction is inherently lower to begin with, so they're more tolerant of environmental contaminants that get into the cables and increase friction.
All the hidden-cabled shifters take more settling in, but it takes longer to get SRAM fully dialled in.
schroeds
Postby schroeds » Sat Jul 06, 2013 10:14 pm
Duck you've redeemed yourself:-)
DavidS
Postby DavidS » Sat Jul 06, 2013 11:21 pm
I ride a flat bar but on my old bike the Sora needed adjusting I think once in 21,000KMs. On the current bike I have 105 and haven't used anything except the barrel adjusters as the new cable stretched a bit. Don't need to use the adjustment screws on the derralieur itself, even when I change a cassette.
DS
