Crank Length
CoffeeNut
Crank Length
Postby CoffeeNut » Mon Jun 16, 2008 9:31 pm
Just noticed I have 170mm cranks on my Shimano 105 53/39
Is 170mm typical? Thought 175mm was more common ??
nzdans
Postby nzdans » Mon Jun 16, 2008 9:33 pm
170mm is the common size for road bikes as it promotes spinning more. The common size for MTBs is 175mm...
Kalgrm
Postby Kalgrm » Mon Jun 16, 2008 9:34 pm
If you've only just noticed, don't worry about it. ;)
Graeme
nzdans
Postby nzdans » Mon Jun 16, 2008 9:45 pm
Sorry, am multi tasking (on marathon call with Mum), what size frame do you ride, how tall are you?
CoffeeNut
Postby CoffeeNut » Mon Jun 16, 2008 9:51 pm
Doing a lot of hills up here in Toowoomba. Contemplating compacts or a triple - so was measuring up some options.
I'm 173cm short, and frame is 52cm Trek - seems to fit well.
531db
Postby 531db » Mon Jun 16, 2008 10:27 pm
CoffeeNut wrote:Doing a lot of hills up here in Toowoomba. Contemplating compacts or a triple - so was measuring up some options.
If your leg length is in proportion to your height of 173cm, 170mm is plenty long enough.
531db (184cm and 165/170mm 'cranker').
Parrott
Postby Parrott » Mon Jun 16, 2008 11:29 pm
Have a go at this site.
CoffeeNut
Postby CoffeeNut » Tue Jun 17, 2008 8:25 am
calculator says 163mm would be ideal.
Users browsing this forum: Cyclophiliac
