700mm rims on MTB frame
Postby markz » Thu Jun 26, 2008 8:16 am
Hi,
I have Giant atx 8xx mtb bike with 26inch wheels with 1.25 inch 100psi tyres.
Has anyone installed 700mm rims on similar bike?
I realize V-brakes might not align with the 700mm rims.
Can new v-brake arm be adjusted? Or new ones purchased?
Mark
markz
by BNA » Thu Jun 26, 2008 10:23 am
Postby bigfriendlyvegan » Thu Jun 26, 2008 10:23 am
Have a look at these:
http://www.mavic.com/mtb/products/Speedcity.995625.aspx
They sound sweet.
David
bigfriendlyvegan
Postby Kalgrm » Thu Jun 26, 2008 10:27 am
On my MTB with disc brakes, the 700c wheels I have fit in nicely. I can't say whether or not your v-brakes can be adjusted far enough for it to work. Some will.
Graeme
Kalgrm
Postby glawrence2000 » Fri Jun 27, 2008 12:58 pm
There are forks available that will take either 26" or 700 wheels; the canti brake studs are in two positions (removable) so you can do what you'd like. They also cater for disc with IS mounts built on as well.
Clearance may be a issue depending on the profile of what tyre you use.
Rear canti levers will be a bit more interesting.
G
Thanks heaps.
BMC 4Stroke 03. (web nazis won't let me put a third picture up :()
Voodoo Dambala 29er.
FELT AR4 Carbon.
glawrence2000
