Tektro RX-5 85mm mini v-brakes Replacements
Postby Aushiker » Fri Jun 27, 2008 8:16 pm
G'day
I have managed to strip the thread on one side of my Tektro RX-5 85mm mini v-brakes (front) screw adjuster so don't have that fine adjustment. I have a bit of a fix in place with the spring bent but would prefer to get it sorted properly.
I can pick up a front no-name v-brake from the LBS for $11.00 net (I have a discount voucher for them) or should I "lash out" on a set of Avid Single Digit 7 2008 or similar (assuming they fit of course)? What I am asking is there likely to be that much difference in performance?
This is on my Giant CRX 1 which is my wet weather commuter so good front brakes are important.
Thoughts?
~ Aushiker.com
LuckyPierre
Re: Tektro RX-5 85mm mini v-brakes Replacements
Postby LuckyPierre » Fri Jun 27, 2008 8:20 pm
Aushiker wrote: ... This is on my Giant CRX 1 which is my wet weather commuter so good front brakes are important ...
Isn't this really the answer to your question?
Postby Aushiker » Fri Jun 27, 2008 8:27 pm
Clearly I don't know which is why I asked "What I am asking is there likely to be that much difference in performance?"
~ Aushiker.com
Caelum
Postby Caelum » Fri Jun 27, 2008 10:17 pm
Perceived performance? :lol:
DO ITTTT :twisted:
Postby munga » Sat Jun 28, 2008 6:47 am
I have '06 avid sd ti brakes with '07 sd7 levers and alligator cables on my farrago and the difference was like night and day. Cost me under $100 from ebay
Postby Aushiker » Sat Jun 28, 2008 4:22 pm
Thanks Caelum and Munga
I dropped into Bike Force at Fremantle and they had a Shimano Deore M-530 front v-brake for $35 so I grabbed that. Longer arms but that shouldn't be an issue on the front. More solid build too. I shall find out if it makes difference once fitted.
For a price comparison the same brake at Chain Reaction is $17.35, however with postage it comes to $38.41.
Regards
~ Aushiker.com
Postby Aushiker » Sun Jun 29, 2008 3:28 pm
G'day
Completed the installation of the Deore brakes this morning. Not without its hassles. More my lack of knowledge/skill than anything. Details on my blog.
Regards
~ Aushiker.com
Users browsing this forum: fergy1987, Quency
