eeekkk, what is this part?
HappyHumber
Re: eeekkk, what is this part?
Postby HappyHumber » Fri Oct 04, 2013 8:05 pm
il padrone wrote:Try this one out for a mystery part :D
Stopwatch or at least fob/pocket watch (the ol' analog sort) holder :P
The URL also partially gives it away too, Pete... tsk.
- Kym
Postby il padrone » Fri Oct 04, 2013 9:54 pm
Yeah, I know it was too easy :D You have it correct, fob-watch holder
Postby Clydesdale Scot » Sat Oct 05, 2013 7:41 am
Tim wrote:IP, that is exactly the clip I have been looking for to mount a tennis racket to the handlebars.
Said tennis racket is for swatting aggro magpies.
then you need one of these
http://www.ebay.co.uk/itm/Vintage-1940s-50s-Bicycle-Tennis-Racket-Holder-/310758921583?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item485aacd56f
as7431
Postby as7431 » Thu Oct 17, 2013 12:30 am
I was talking to a friend who has campy running gear and looked down and saw these small red tubes on the end of his cables, where you normally put crimp on metal bits. I thought that they looked familiar, but took me some time before I remembered where. They appeared identical to the OPs photos
Tim
eeksll
Postby eeksll » Thu Oct 17, 2013 8:23 am
thanks, now that you say it, the rear shift cable did not have a crimp on metal bit. I just assumed the LBS forgot it.
However, the other 3 cable ends did have metal crimp on bits.
def
Postby def » Thu Oct 17, 2013 12:25 pm
I'd say that was a clip for mounting a stop-watch on your handlebars. For the time before electronic bike computers.
Users browsing this forum: Bing [Bot], leovendramini, StevOz
