How To Securely Fasten Zip Ties
Postby Aushiker » Sat Jun 28, 2008 7:34 pm
G'day
This video has just popped up at BicycleTutor.com and I thought it was worth sharing. They are suggesting using a fourth (third) hand cable tool to tighten zip ties. Seems a good idea to me anyway.
http://bicycletutor.com/fasten-zip-ties/
Regards
by BNA » Sat Jun 28, 2008 7:37 pm
Postby lisanne » Sat Jun 28, 2008 7:37 pm
What a nifty tool!
lisanne
Postby Matty » Sun Jun 29, 2008 3:06 am
If you don't happen to have a third hand tool, you can always use this tool from Jaycar. It'll tighten AND cut your zip tie :lol:
Matty
Postby Bnej » Sun Jun 29, 2008 7:51 am
I just use pliers to get an extra few clicks on the zip tie, works fine.
Bnej
Postby thomas_cho » Sun Jun 29, 2008 9:31 am
thanks for the tip. This is quite handy.
thomas_cho
Postby nzdans » Sun Jun 29, 2008 9:53 am
I tried this a few years back, it's a nice gimmick but can be a bit too easy to snap smaller ties as the tool has a bit too much leverage! :roll:
nzdans
Postby MountGower » Sun Jun 29, 2008 10:50 am
If your snapping cable ties under tension, there are two solutions. Use a better quality cable tie. There are so many different brands out there these days and most are rubbish. Thomas&Betts are the best. The other solution is to use a wider tie. Probably a combination of both quality and size is the go.
Also, the success of the use of a cable tie can depend very heavily on the point of the circumference at which you place the join. Remember that the job is round, but the join is initially at right angles.
MountGower
Postby il padrone » Sun Jun 29, 2008 1:25 pm
If I use pliers and can't get any more clicks from the zip tie, will this tool make them any tighter?
Postby Aushiker » Sun Jun 29, 2008 3:25 pm
G'day
I used my Park Tools Fourth hand on some cable ties and it worked a treat. I will now go and replace the cable ties on Chase using this tool.
Regards
Postby geoffs » Fri Jul 04, 2008 5:47 pm
It looks a nice tool but then the bicycle tutor stuffs up his good work by using an ordinary pair of side cutters to cut the cable tie.
It's always better to use flush cutters for cutting cable ties if you don't wont the little end sticking out that is sharp enough to cut yourself on.
Flush cutters are available from electronics stores like Jaycar.
Geoff
geoffs
Postby HaywarM » Wed Jul 09, 2008 2:51 pm
I've only ever used cable ties on a bike for speedo wires, and mounts. How tight do you need you cable ties to be?! i would be concerned about damaging the wire.
We use a tool offshore for stainless cable ties that is designed so that it pulls tight until the tail snaps off, so a sharp edge is not left behind. but i wouldn't be too keen to try it around bike tubing (carpet fibre, alloy or even steel for that matter).
Felt f5c - plus dura ace
Raceline Giro - on the trainer and in the wet
Geoff Scott 80s - Stripped and fixed
1993 CroMo mountain bike - kids seats front and back
If we learn anything from history, it is that we learn nothing from history.
HaywarM
Users browsing this forum: loucastillo
