Mounting a pannier rack on bike without mounting lugs
• Page 1 of 1
Mounting a pannier rack on bike without mounting lugsHi there,
I am trying to mount a rear rack on my Kenevans bike which does not have mounting lugs. I do not want to use seatpost mounted racks. Are there alternative solutions? Thanks
I recall hearing around here that there's band clamps to go round the seatstay with holes for mounting bolts. Front of the rack to the seatpost binder? Anybody else got a better memory?
Shaun ...whatever the road rules, self-preservation is the absolute priority for a cyclist when mixing it with motorised traffic.
Metal P clamps with some heatshrink shrunk around then, or some innertube between the clamp and the seatstays would be the way to go.
An alternative I used was one top strap on a Topeak rack to a plastic reflector bracket around the seat tube.
Does the Ken Evans have drop-out mounts?
If so, and you want to avoid the possible marring of the frame finish using P-clamps, you could get yourself a Tubus Fly brake-stay mounted rack. This smaller Tubus rack is every bit as rigid as the Cargo, and heaps more solid than any Topeak/Blackburn-copy alloy rack. I've carried full-sized rear panniers on it, with a tent and sleeping mat on top, and it performed very well. Riding bikes in traffic - what seems dangerous is usually safe; what seems safe is often more dangerous.
Thanks for the tips.
The Ken does not have the drop out mounts. So I think I will try the P-clips. Are these readily available at Bunnings? I have a friend who fashioned a brake caliper mount out of a metal ruler he bought at the $2 shops. I think I will try and P-Clips at the seat stay positions first.
I've used the P-clamps, but they will eventually rub on the frame. I purchased mine at a bike store. They potentially are available at Bunnings, but by the time you spend the 1/2 hour trying to find them, it may be quicker at the bike shop.
Are P-clamps predominantly used in the electrical section?
Where do I even start to look for them in Bunnings? Well I am not afraid to get rub marks on my bike ... as its just a rattle-can spray job.
These are what you're after. Wallbike are very helpful, so you could email them and see if they'll stick some in an postpack for you. Or a LBS may have these. I don't know whether Bunnings would have them... maybe.
I wonder about the usefulness of some of the polypipe clamps for this?
The sort you use for reticulation. they are normally less than a dollar each - but I haven't thought much about this - what diameter clamps, what sort of clamp would hold solid enough etc? They are plastic but may still be had enough to scratch? Just a thought!
Okay bought some of those p-clips (LBS called them U-clips). LBS was pretty good, charged me $2 for 4 pieces. Will try them on tonight.
Standard Old Man Mountain racks are designed to attach to the V-brake/cantilever mounts. So if your Ken Evans has road cantis....
You could rig this up by just omitting the little right-angle mounting bracket. Riding bikes in traffic - what seems dangerous is usually safe; what seems safe is often more dangerous.
• Page 1 of 1
