Where's my Fulcrum freehub noise gone?
cjrich
Postby cjrich » Sun Oct 13, 2013 2:24 pm
Hi all
My Fulcrum 5's are far from new but still good condition. Noticed today the freehub no longer makes the clicking sound when freewheeling. Pulled the cassette off, inspection and cleaned cassette and external freehub. Still no clicking.
Does this indicate a hub problem? I want my noise back :(
CJ
CJ
- 2015 Cervelo R3
- 2014 Avanti Blade 3
Pottsy
Re: Where's my Fulcrum freehub noise gone?
Postby Pottsy » Sun Oct 13, 2013 9:31 pm
take the freehub off & inspect it.
It could be damaged or filled with gunk.
im_no_pro
Postby im_no_pro » Sun Oct 13, 2013 10:04 pm
Pottsy wrote:take the freehub off & inspect it.
This +1. Regrease it, the lighter the grease the louder the freehub.
Sent from my GT-I9210T using Tapatalk
Velo13
Postby Velo13 » Tue Oct 15, 2013 12:40 pm
Might be best to clean/degrease the pawls thoroughly and use a mid weight oil instead of grease. I suspect that there is some stickiness in there and/or the pawl spring is weak - that is stopping the pawls from "flinging out" and engaging with a "snap" or solid "click". Grease may even be sitting in the engagement ring - that quietens them down as bit as well.
Even better, get a new pawl spring and pawls - not expensive - and check them in whilst you have it apart.
cjrich
Postby cjrich » Tue Oct 15, 2013 6:41 pm
Turned out to be a broken pawl spring. Will try to source new spring and pawls, or new freehub.
Hopefully not too exe, rather put the money towards new wheel set. Glad I have a spare wheel set to use in the meantime.
BTW, can someone please give me the installation order for the 3 axle spacers, as usual I was in a hurry and didn't take note.
Thanks people.
CJ
CJ
- 2015 Cervelo R3
Velo13
Postby Velo13 » Wed Oct 16, 2013 11:22 am
cjrich wrote:BTW, can someone please give me the installation order for the 3 axle spacers, as usual I was in a hurry and didn't take note.
You can get excellent diagrams on all products from the Fulcrum website.
