Rim Widths
bianchi928
Rim Widths
Postby bianchi928 » Thu Oct 17, 2013 3:27 pm
Hi all,
I am considering some new wheels, carbon with alloy braking surfaces.
In the early stages of my investigations, I have notices some are 23mm and others 25mm.
I currently run 700 x 25 tyres on my Bontrager RXL's and do not wish to go back to 700 x 23.
Assuming the 23mm and 25mm are the rim width, could I purchase either and still run the 700 x 25 tyres or if I sell them, could you run a 700 x 23 on the 25mm (phew)
Thanks for your assistance.
Stand on my dog I cut off your head
biker jk
Re: Rim Widths
Postby biker jk » Thu Oct 17, 2013 3:50 pm
My understanding is that it's the internal rim width that matters with regard to tyre fit. So you can mount a 23mm tyre on a 25mm wide rim (internal width will be around 17-18mm). My 23mm wide tyres on 23mm wide rims measure 25mm across. So bear in mind that your 25mm wide tyres on a 25mm wide rim could measure 28mm wide so make sure you have the clearance to do it.
eeksll
Re: Rim Widths
Postby eeksll » Thu Oct 17, 2013 3:55 pm
Hopefully you can find out what tyre sizes fit the rim your buying !!! Surely the manufacturer releases some specs.
Sheldon Brown has a chart on it here
http://sheldonbrown.com/tire-sizing.html (see Width Considerations)
Re: Rim Widths
Postby Duck! » Thu Oct 17, 2013 8:38 pm
The 23 & 25 you're referring to is the tyre width, NOT the rim width.
As biker jk points out, rims are measured between the hooks of the beads - each sidewall/bead has a P-profile facing inward, the width is measured between the opposing P's. Road rims are typically 14-17mm wide measured this way, hybrid/MTB rims 17-21mm, heavy-duty MTB rims 23+mm.
bianchi928
Re: Rim Widths
Postby bianchi928 » Thu Oct 17, 2013 10:43 pm
Thanks all.
