How often do you find yourself pumping up your tyres?
jlh
Re: How often do you find yourself pumping up your tyres?
Postby jlh » Sun Nov 03, 2013 8:04 pm
As others have said, at the start of each ride.
Postby RonK » Sun Nov 03, 2013 8:24 pm
Once a week.
Marteau
Postby Marteau » Mon Nov 04, 2013 8:33 am
When they need it ... simply you should be running your hands over your tyre's before every ride for debris and also pressure. Simple as that.
michael_w
Postby michael_w » Mon Nov 04, 2013 11:10 am
Thanks everybody for the responses. It helps to confirm that I'm not crazy and that in fact deflation is part of the normal operation. I tend to pump the tyres up at least once a week and that is generally after I give it the squeeze test and think "Yep, it's time again"
Baldy
Postby Baldy » Mon Nov 04, 2013 12:15 pm
I have never once found myself pumping up my tyres, I usually have to do it myself.
Plus meeting yourself can damage time and space and make your chain go flat.[The Bogani effect]
Postby bychosis » Mon Nov 04, 2013 12:41 pm
I've never had to pump up my chain. Fortunately because that needs a really high pressure pump and I've only got a high pressure pump for my shocks.
