Scratch build Commuter/Tourer all welcome!
Posted: Wed Jan 08, 2014 5:23 pm
OK well let me get lubricated. Sick of the impossible task of selecting an off the shelf model due to the plethora of combinations and mainly the small front rings I have decided to build my own. I have ridden daily for 30 years and raced, toured on a number of bikes. I have not had a good off the shelf model since a modified Giant Innova many years ago for touring. So I know what I want, I am just not up to speed on parts over the last ten years. What I want seems to cost about $2500 off the shelf, but I am sure we can do better.
So I have bouoght a frame, the Soma Double Cross DC as the base.
Tange Prestige heat-treated CrMo front triangle; butted CrMo rear end
- Clearance for 700x38c tyres with mudguards
- Rear spacing is 132.5 and fits road or mtn hubs.
Disc mount is located on the chainstay which allows you to put almost any rear rack or mudguard on it. Rear disc mounts fits 160mm rotors only.
I get it tomorrow. I chose this for the price, $390 delivered from Abbotsford Cycles, the materials, and the mounts. I fell in love with that rear end, I want mine to look the same.
Now I need front forks, I have kinda decided on these forks http://store.interlocracing.com/taprlucxfrk1.html" onclick="window.open(this.href);return false;
Unless someone can point me to something local that will do the trick for less money. Any ideas? Ive spent hours looking and there is not much around. I will need a recommendation for headstem gear so I can fit the forks.
My next concern is wheels, I need a recommendation for 700c rims with 6 bolt sealed disc hubs for Avid brakes. I will go to $400 on those, any ideas? I have avid rear brake already. I dont need wide tyres so 29 inchers are out, I dunno about 26 inch, Im open to suggestions on those. I carry about 35 kilos on each back pannier, so I need strength. My old wheelbuilder died, so I am at aa loss.
Now I know its not so simple, we need to decide on drive train to get right hub. Im very open here. Only thing is I need a min of 50-52 tooth front ring. 2 or 3 front chain ring doenst matter and whatever does the trick on the rear, 7,8,9,10.
So then shifters and derailleurs have to be considered, once again open on those.
Any advice will be greatly appreciated and decisions made quickly. Its been a while since I built a bike, I used to be pretty good but times change.
I have looked at many groupsets, its hard to find big front chain rings unless its racing gear. I need levers for flat bars too, so thats a limiting option, so many limits, thats why i am considering building part by part not with a groupie.
This is my first build with disc brakes so its throwing me right off! If it was a racer, Id just shove 105 on it and be done with it!
I have considered buying another bike and stripping it, the Apollo transfer 40 for example for $800 and selling the frame see http://www.apollobikes.com/bikes14/rail ... szub7RpuZ8" onclick="window.open(this.href);return false;
I wonder if something like that would be an option?
Overall, I want it on the road within 6 weeks.
Help!
Help!
Help!
Help!
