TCR Advanced brake cable stops/guides
hoju79
Postby hoju79 » Mon Jan 13, 2014 7:11 pm
Hi everyone,
I have purchased a 2012 Giant TCR Advanced frameset and have found that I am missing the black cable stop/guide that pushes into the frame for the rear brake, near the seatpost. I thought that should be a fairly easy part to obtain as it is essentially a small black plastic stopper with a short length of narrow cable sheath. Google searches haven't brought up anything useful yet. I have been to two Giant dealers so far and neither have had to order them before and are doubting the availability of them. They look the same on all 2012-2014 TCR and Defy internal routed models that I have looked at.
Does anyone know where to source them? Or does anyone have a spare one in a broken frame, and could send one to me at my cost?
Any advice or help much appreciated.
Josh
Re: TCR Advanced brake cable stops/guides
Postby Mulger bill » Mon Jan 13, 2014 7:44 pm
G'Day Josh, welcome outside. :)
Is this the sort of thing you're looking for?
It's a ferrule (cable end cap) from one of various Jagwire cable kits. Not sure if you can buy them seperately, a quick ebay search might do the trick.
HTH
Shaun
mitchy_
Postby mitchy_ » Mon Jan 13, 2014 7:47 pm
just make sure you get the right size (5mm) correct me if i'm wrong, but those nosed ferrules as above are usually for 4/4.5mm shift cables?
Designs by Mitch - drafting specialist.
hoju79
Postby hoju79 » Mon Jan 13, 2014 9:54 pm
Thanks for the replies guys. The picture looks very close.
Here is the end cap from the handlebar end:
The critical part is the narrower part of the cap which is 4mm in diameter. This section inserts into the hole in the frame. The wider part that sits externally to accept the cable end is approx 7mm externally with a 5mm hole. Is this a standard size cap? Or is it specific to Giant?
Josh
mitchy_
Postby mitchy_ » Mon Jan 13, 2014 9:57 pm
that one in particular looks specific to giant, but have you tried a regular ferrule?
hoju79
Postby hoju79 » Mon Jan 13, 2014 11:40 pm
Looks like I need a Jagwire POP Ferrule. They come with some of their cable kits. It takes a 5mm cable down to a 4mm hole. Thanks for the help guys, once I used the correct terminology I found it fairly quickly.
Josh
dale79
Postby dale79 » Sat Jan 18, 2014 3:29 pm
I have a set somewhere,.. but I usually run a full length brake outer from handle to brake.. much smoother and better feel.. you can thread the outer through the frame no problems at all
dale79
Postby dale79 » Sat Jan 18, 2014 4:26 pm
I've got 3 sets of brake ones and a set of shifter ones.. If your in syd can pick up a set if you want??
hoju79
Postby hoju79 » Sat Jan 18, 2014 11:11 pm
Thanks Dale,
I have PM'ed you.
Josh
dmwill
Postby dmwill » Mon Dec 01, 2014 1:50 am
Small bump!
Just picked up a TCR TDF Edition frame.
Planning on fitting a mechanical groupset in the interim. (TDF edition has Di2, but like all TCR frames, can accommodate mechanical)
May need to get hold of these cable stops for the rear brake (2 required there) and both gear cables (3 required I think - 2 for head tube and 1 for the chain stay). Where can I get them from the quickest? Google didn't really help me.
Cmm
Postby Cmm » Mon Dec 01, 2014 6:55 am
From me dmwill ill pm you
