Page 1 of 1
TCR Advanced brake cable stops/guides
Posted: Mon Jan 13, 2014 7:11 pm
by hoju79
Hi everyone,
I have purchased a 2012 Giant TCR Advanced frameset and have found that I am missing the black cable stop/guide that pushes into the frame for the rear brake, near the seatpost. I thought that should be a fairly easy part to obtain as it is essentially a small black plastic stopper with a short length of narrow cable sheath. Google searches haven't brought up anything useful yet. I have been to two Giant dealers so far and neither have had to order them before and are doubting the availability of them. They look the same on all 2012-2014 TCR and Defy internal routed models that I have looked at.
Does anyone know where to source them? Or does anyone have a spare one in a broken frame, and could send one to me at my cost?
Any advice or help much appreciated.
Josh
Re: TCR Advanced brake cable stops/guides
Posted: Mon Jan 13, 2014 7:44 pm
by Mulger bill
G'Day Josh, welcome outside.
Is this the sort of thing you're looking for?
It's a ferrule (cable end cap) from one of various Jagwire cable kits. Not sure if you can buy them seperately, a quick ebay search might do the trick.
HTH
Shaun
Posted: Mon Jan 13, 2014 7:47 pm
by mitchy_
just make sure you get the right size (5mm) correct me if i'm wrong, but those nosed ferrules as above are usually for 4/4.5mm shift cables?
Posted: Mon Jan 13, 2014 9:54 pm
by hoju79
Thanks for the replies guys. The picture looks very close.
Here is the end cap from the handlebar end:
The critical part is the narrower part of the cap which is 4mm in diameter. This section inserts into the hole in the frame. The wider part that sits externally to accept the cable end is approx 7mm externally with a 5mm hole. Is this a standard size cap? Or is it specific to Giant?
Josh
Posted: Mon Jan 13, 2014 9:57 pm
by mitchy_
that one in particular looks specific to giant, but have you tried a regular ferrule?
Posted: Mon Jan 13, 2014 11:40 pm
by hoju79
Looks like I need a Jagwire POP Ferrule. They come with some of their cable kits. It takes a 5mm cable down to a 4mm hole. Thanks for the help guys, once I used the correct terminology I found it fairly quickly.
Josh
Posted: Sat Jan 18, 2014 3:29 pm
by dale79
I have a set somewhere,.. but I usually run a full length brake outer from handle to brake.. much smoother and better feel.. you can thread the outer through the frame no problems at all
Posted: Sat Jan 18, 2014 4:26 pm
by dale79
I've got 3 sets of brake ones and a set of shifter ones.. If your in syd can pick up a set if you want??
Posted: Sat Jan 18, 2014 11:11 pm
by hoju79
Thanks Dale,
I have PM'ed you.
Josh
Posted: Mon Dec 01, 2014 1:50 am
by dmwill
Small bump!
Just picked up a TCR TDF Edition frame.
Planning on fitting a mechanical groupset in the interim. (TDF edition has Di2, but like all TCR frames, can accommodate mechanical)
May need to get hold of these cable stops for the rear brake (2 required there) and both gear cables (3 required I think - 2 for head tube and 1 for the chain stay). Where can I get them from the quickest? Google didn't really help me.
Posted: Mon Dec 01, 2014 6:55 am
by Cmm
From me dmwill ill pm you
Posted: Fri Oct 11, 2019 11:02 pm
by warthog1
Thread dig, came up on a google search, but I am now in the same boat.
I just bought a 2nd hand 2013 tcr advanced 0.
It came out as di2. Has no cable stops for the shifter cables at the steerer or the drive side chainstay.
Any ideas?
I'll check the local Giant dealer out on Tuesday.
Posted: Fri Oct 11, 2019 11:13 pm
by warthog1
Posted: Mon Aug 03, 2020 12:39 pm
by Shannbb
Hi Guys,
Massive long shot but I am after the cable stops for the shifter cables at the handlebar end of the frame.
Can anyone help out?
Posted: Mon Aug 03, 2020 1:57 pm
by Duck!
They are available through Giant.
