Latest Reviews and Articles
Will your next bike be Intelligent? ABS and Smart Bike Tech
Vitus Vitesse EVO Disc Review – Speed Machine indeed!
Campag Khamsin wheel bearing play
- KGB
Postby KGB » Fri Jan 17, 2014 10:14 pm
The wheels have roughly 8,000-10,000km on them. I'm a lightweight weakling who generally looks after my gear very well. I'm a little surprised that they have issues although can't really complain since they've performed admirably for the grand price of $187 shipped from Wiggle a couple of years ago.
I'm confident I can sort this myself, just looking for any special tips that might be out there. Hopefully they'll use a generic bearing size that I can get cheaply, unlike UT cranks which use a narrow bearing that I can't find ANYWHERE except the genuine ones.
I'll post back with the outcome and part numbers, costs etc in case anyone is interested.
- KGB
Re: Campag Khamsin wheel bearing play
Postby KGB » Sun Jan 19, 2014 12:28 pm
- Nikolai
Postby Nikolai » Sun Jan 19, 2014 4:03 pm
- KGB
Postby KGB » Tue Jan 21, 2014 9:09 am
I actually ordered a pack of 10 bearings, they were cheap enough that once I included postage it wasn't much more than just getting a couple. If they are decent, I'll send you a couple of spares when they arrive here.
- silentbutdeadly
Postby silentbutdeadly » Tue Jan 21, 2014 11:25 am
Any bearing shoppe has the 6001 bearings and they aren't expensive - even the good ones. Both the Campag and Fulcrum wheels suffer from cheap rubbish bearings straight from the off...
Another source is the local Enduro bearing distro, DIYMTB. They have the standard 6001 for $4.50, the ABEC5 version (called 61001) for $11.50, the ceramic version for $23.55 and ceramic hybrid version for $40.81. Personally, I'd run to the ABEC 5 version rather than go ceramic. Especially if your rear hub has four bearings in it!!!
- Nikolai
Postby Nikolai » Tue Jan 21, 2014 2:18 pm
- KGB
Postby KGB » Sat Jan 25, 2014 12:53 pm
- KGB
Postby KGB » Mon Apr 14, 2014 9:29 pm
I finally diasassembled the wheel, which was very easy. So easy its not even really worth describing, just get a pair of 17mm spanners on the lock nuts and undo... Just make sure you lay everything out in the right order so you don't mess up the reassembly.
First step, put the new bearings in the freezer. Probably doesn't make much difference but any contraction/shrinkage will help.
I used a 12mm dynabolt as a blind bearing puller: insert into the bearing, tighten the dynabolt to wedge inside and then tap out from the opposite side. Easy.
To put the new bearings in, I heated the empty hub body with a heat gun to help it expand. Not too much and not too fast. I figured it was better to play it safe rather than risk ruining any heat treatment on the spoke heads and freewheel ratchet race (I know this would probably require 500 deg + and for longer than I was working...). New bearings were tapped in with a rubber mallet until flush with the outer edge of the hub and then I carefully tapped them into place using a mallet and a large socket. My large spark plug socket is almost an exact fit for the bearing, meaning it rests on the outer race only and won't cause any side-loading while tapping them in. They ended up going in quite easily anyway.
No more play, no more crunchiness when spinning the axle. There is 4 bearings in the rear hub, two 6001 RS bearings in the hub body and two 6901 2RS bearings in the freewheel. I didn't have the 6901's but luckily they felt fine and I had no choice anyway but to leave them. The 6001 bearings are only a single RS as already mentioned in this thread. It was my non-drive side bearing that failed, it was nice and brown and dirty when I pulled it out. New bearings are 2RS.
I have plenty of spare 6001 2RS bearings now, if anyone needs a couple just give me a yell. Nikolai; if you want pics or more detail just send me a PM.
- QuangVuong
Postby QuangVuong » Mon Apr 14, 2014 11:25 pm
- KGB
Postby KGB » Wed Apr 16, 2014 11:57 am
The dynabolt worked a treat although it does get a bit mangled. You really only need it for the first bearing (either one). Once that's out you can remove the spacer that sits between them and you have a free shot at the other side.
- Storm Boy
Postby Storm Boy » Fri Mar 06, 2015 10:15 am
I picked up a set of these wheels from Wiggle a few days ago and would like to keep a spare set of bearings, or even change over the factory bearings for a better set, as these will be my wet weather wheels. Just wondering if you know which bearings are used in the front wheel?
Cheers!
SB
- KGB
Postby KGB » Fri Mar 06, 2015 1:52 pm
Luckily, it is super easy to check. The "cones" or lock nuts are really just cap pieces that thread on to a central axle. A spanner on each side and they're straight off, allowing you to read the bearing size straight from the bearing. If I get a chance I'll open them up and post the size here - I assume you haven't received your wheels yet.
- Storm Boy
Postby Storm Boy » Fri Mar 06, 2015 2:17 pm
Thanks for that. I actually have received the wheels, and just put tyres on last night. If it's that easy I should be able to do it myself
Regards,
SB
- Cyclocross
- Cycling Brands
- Azzurri
- Bianchi
- BMC
- Campagnolo
- Cannondale
- Cervélo
- Colnago
- Focus
- Fuji
- Garmin
- Giant
- Malvern Star
- Merida
- Scott
- Shimano
- Specialized
- SRAM
- Surly
- Trek
- Custom Builders
- Generic Carbon
- Delete all board cookies
The largest cycling discussion forum in Australia for all things bike; from new riders to seasoned bike nuts, the Australian Cycling Forums are a welcoming community where you can ask questions and talk about the type of bikes and cycling topics you like.
