Garmin 500 problem - lost satellite reception
Ross
Postby Ross » Sat Jan 18, 2014 6:15 pm
Went for a ride today in an area I've ridden dozens of times before but today as I ws riding along my Garmin lost satellite reception. Sky was near cloudless and there was no tree cover. I pressed the stop and then start button and after a minute or so the reception improved. Later in the ride this happened again but I didn't stop or restart this time and the screen display kept telling me for the rest of the ride (about 30 minutes) that I had no reception but when I got home and uploaded to Strava the complete ride was there as per normal. Any ideas what's going on? Garmin unit is only a few months old and has performed flawlessly up until today.
Re: Garmin 500 problem - lost satellite reception
Postby Duck! » Sat Jan 18, 2014 6:39 pm
Have you deleted your old ride data after offloading it to Strava or wherever? They can go a bit mental when the memory fills up.
cancan64
Postby cancan64 » Sat Jan 18, 2014 6:52 pm
Funny my garmen 500 done the same thing... I pulled over, turned it off and back in and didn't have a problem for the rest of the ride.... Maybe there I'd a harken conspiracy happening
Sent from my GT-I9305T using Tapatalk
Dr_Mutley
Postby Dr_Mutley » Sun Jan 19, 2014 12:03 am
It's not uncommon for the GPS chip to lift away from the PCB in the 500s... Do all the simple software related things first, then if u have no luck, pull the back off and have a look...
Ross
Postby Ross » Sun Jan 19, 2014 6:26 am
Duck! wrote:Have you deleted your old ride data after offloading it to Strava or wherever? They can go a bit mental when the memory fills up.
Yep. Only ride in Garmin was the one I was currently doing.
Ross
Postby Ross » Sun Jan 19, 2014 11:04 am
Didn't do it on today's ride, must of been a one-off glitch. Hopefully.
queequeg
Postby queequeg » Sun Jan 19, 2014 11:13 am
happened to me on Friday too. it has done it a few times over the last 4 years, and I find that turning it off and back on fixes it, otherwise it sits there trying to find a satellite for the rest of the ride.
Postby Duck! » Sun Jan 19, 2014 1:27 pm
It could be that there weren't enough satellites in the ideal field of reception for your unit to pick up properly. There are stacks of the things floating around up there, so such a dropout is pretty rare, but not impossible.
warthog1
Postby warthog1 » Sun Jan 19, 2014 1:37 pm
Mine has done what you describe maybe 4 times in the 18 months or so I've had it. No rhyme or reason to it I can see. Last time was a couple of weeks ago, been fine since.
Postby Aushiker » Sun Jan 19, 2014 6:21 pm
If you do a search you will find it is fairly common problem it seems ... I had one of Edge 800 have to go back because of this problem ... eventually gave up on the replacement which started doing the same thing and brought a Edge 810.
macca33
Postby macca33 » Sun Jan 19, 2014 6:55 pm
Had it occur to me twice in around 300 rides. First time I ignored it and the cadence/speed sensor calculated the distance, but the satellite track was AWOL.
Second time I stopped and allowed it to re-acquire satellites and it was fine from thereon.
warthog1
Postby warthog1 » Fri Jan 31, 2014 2:14 pm
Did it again a couple of times last week. Each time I pressed enter and it seemed to work again. It is a PITA, if it kept doing it I reckon it would be punished severly. It would probably meet the same fate as my old polar cs200 :x
Dr_Mutley
Postby Dr_Mutley » Fri Jan 31, 2014 2:50 pm
Save the setting file off the unit, then do a master reset... Update or reload the firmware, then see place the settings file... See if that helps...
wizardhat
Postby wizardhat » Wed Feb 12, 2014 9:12 am
My 500 was perfect up until 3 weeks ago, now it loses GPS lock 5 or 6 times a ride on one day, but then is perfect the next. I've tried all the software related fixes so I guess I'm going to have to pull the back off and see if the GPS chip has come loose.
Aushiker wrote:If you do a search you will find it is fairly common problem it seems ... I had one of Edge 800 have to go back because of this problem ... eventually gave up on the replacement which started doing the same thing and brought a Edge 810.
Has your 810 had any problems since you got it? If I have to replace my 500 I want to replace it with something not afflicted by this :(
warthog1
Postby warthog1 » Wed Feb 12, 2014 2:33 pm
Dr_Mutley wrote:Save the setting file off the unit, then do a master reset... Update or reload the firmware, then see place the settings file... See if that helps...
Sorry didn't read this 'til now, thanks :)
It hasn't done it again since :? I'll leave it alone whilst it behaves.
Postby Aushiker » Wed Feb 12, 2014 2:50 pm
wizardhat wrote:Has your 810 had any problems since you got it? If I have to replace my 500 I want to replace it with something not afflicted by this :(
At risk of bring the Garmin God down on my head, no :)
Users browsing this forum: headasunder, OnTrackZeD
