How to remove/replace decals on Zipp wheels?
Ross
Postby Ross » Sat Jan 18, 2014 6:26 pm
I'd like to remove the decals from my ZIpp wheels and replace them with the later 'Beyond Black' version, how do I do this?
Re: How to remove/replace decals on Zipp wheels?
Postby Duck! » Sat Jan 18, 2014 6:30 pm
With a lot of patience!
Basically just start at a corner, use a very sharp blade to carefully pick it up & peel away. If you try to rush, they'll tear and you'll have to pick off lots of tiny bits. Go gently & they should come off more intact, therefore easily. Clean any sticky residue off with eucalyptus oil.
pawnii
Postby pawnii » Sat Jan 18, 2014 6:59 pm
They are no more than normal vinyl stickers.
Just peel off with finger nail. Clean with acetone or Brake cleaner and stick the new ones on.
I remember Zipp had a DIY YouTube link on there website to do this.
Sent from my iPhone using Tapatalk
yes, I'm an overweight weight weenie
2012 Scott Foil Premium
pawnii
Postby pawnii » Sat Jan 18, 2014 7:02 pm
Eucalyptus oil may leave a residue. Acetone's always a safe bet with carbon.
diventare
Postby diventare » Sat Jan 18, 2014 8:12 pm
Get a hair drier and warm the vinyl up and they will peel straight off without tearing (not talking about blistering heat here).
Used this method many times over the years to get vinyl off plastic and metal surfaces. Turns 40 mins of picking and tearing into 5 minutes of heat and peel.
Dr_Mutley
Postby Dr_Mutley » Sun Jan 19, 2014 12:01 am
Carefully use a hair dryer and its easy... Too much heat will warp carbon rims however...
Clean with alcohol...
Then apply decals with wet method... Ie spray bottle with a small amount of dish washing liquid in it... Spray rim til wet...apply decal... Move to desired place on rim... Push any bubbles out... Leave to dry...
