Good place in Melbourne to get tubs glued on
jasonssv
Postby jasonssv » Sun Jan 19, 2014 7:31 am
Just looking for a recommendation of a good shop to get some tubulars glued on in Melbourne area,
I usually do it myself but have a new set and would rather get an expert on these.
Re: Good place in Melbourne to get tubs glued on
Postby Duck! » Sun Jan 19, 2014 1:05 pm
I work in Frankston if that's convenient for you. :-)
open roader
Postby open roader » Sun Jan 19, 2014 7:35 pm
jasonssv wrote:I usually do it myself but have a new set and would rather get an expert on these.
Why pay someone to do something you have the skills to do yourself?
After seeing a few fairly poor glue jobs myself supposedly performed by alleged 'experts' who charged for their services, now I only trust my own glue up skills. If there is a technical flaw with your own glue job - it's your own fault - don't risk your teeth on someone else's glue job- esp. if you have worked with gluing singles before.
For a fresh pair of tub rims I add 3 very fine layers to the rims - one at a time with 24hr cure time in between. If the hoops are also fresh then 2 x layers of glue on the tapes - again with 24hr between layers. Then a 4th layer onto the rim - allow this one to just to get tacky then whip on the hoops. Align on the rim, add plenty of air and wait another 24hr before riding. Done this with 2 sets of brand new tubular wheelsets with neat and safe results.
If you have done it before then just take the extra time to glue your own from fresh.
ironhanglider
Postby ironhanglider » Sun Jan 19, 2014 9:34 pm
+1
Other people don't have their skin on the line. Do your own glue job. The above method will work well (although I use different nomenclature).
Cameron
